6.7 straight pipe, yes!
Old Sep 19, 2017 | 09:52 AM
RenoHuskerDu's Avatar
RenoHuskerDu
Nobody seems to have posted about straight pipes yet. I installed a cat-back straight pipe on my 350 and it sounds .... OK, but still too quiet. The DPF is effectively a huge muffler that eliminates most of the exhaust tone. A straight pipe like this one only removes the resonator, giving the exhaust slightly more tone when you accelerate, but having little to no effect in other conditions. I'm reluctant to do a full DPF delete while the truck is still under warranty. But one day... heh heh heh heh
Here's a little vid of how quiet my 'straight pipe' is.
Old Sep 19, 2017 | 10:21 AM
triniexr's Avatar
triniexr
You need someone to revv the vehicle while recording. I'm interested in how it sounds. If you could, do a drive by as well.
Old Sep 19, 2017 | 11:04 AM
airpilikia's Avatar
airpilikia
Old Sep 20, 2017 | 04:14 PM
RenoHuskerDu
Here is a drive by video. It's still very quiet. I might have to live with this until I can do a delete after the warranty is up.
Old Sep 20, 2017 | 11:59 PM
airpilikia's Avatar
airpilikia
Thanks! That sounds great.
Old Sep 21, 2017 | 06:57 AM
kylant's Avatar
kylant
not technically a "straight pipe"
can you post the part number you used?
thanks
Old Sep 21, 2017 | 07:01 AM
triniexr's Avatar
triniexr
Sounds good!
Isn't not having those holes in your tailpipe not good?
Old Sep 21, 2017 | 07:33 AM
wfedwar's Avatar
wfedwar
Sounds good!
I was wondering the same thing. Ford calls out the cleaning of those holes as a routine maintenance item. I always wondered what the function was supposed to be.
Old Sep 21, 2017 | 08:23 AM
CACRanger's Avatar
CACRanger
Yeah, I was under the impression that the holes were to draw in cooler air while the DPF was running a regen, which creates a lot of heat. Pulling in cooler air would cool the exhaust exiting the tip and thus not cause paint issues.
I installed a 5" MBRP filter back setup and it has holes in the pipe right before the tip. You can see them in the picture below (just behind the tire).
Old Sep 21, 2017 | 08:50 AM
triniexr's Avatar
triniexr
Hmmmmm, OP, Did you make sure that the exhaust is for a diesel and not a gas? Just don't want to see you run into issues in the future.
Old Sep 21, 2017 | 08:51 AM
CACRanger's Avatar
CACRanger
Yeah, RenoHuskerDu, what part number did you use?
Old Sep 21, 2017 | 09:14 AM
honda250xtitan's Avatar
honda250xtitan
that looks awesome.
how much you guys paying for a glorified tailpipe? sawzall and a piece of 3" or whatever diameter the exhaust is would give you the same result
Old Sep 21, 2017 | 09:20 AM
CACRanger's Avatar
CACRanger
Originally Posted by honda250xtitan
that looks awesome.
Agreed, It could easily be cheaper piecing it together. But, MBRP builds a nice setup and what's $250-300 on a $70k+ truck???
Old Sep 21, 2017 | 11:15 AM
Tricon's Avatar
Tricon
Straight pipe means you have only a pipe from the turbo back to the tail.
Those holes on the end of the tail pipe pull cool air into the exhaust stream, effectively creating a low pressure effect that pulls the hotter exhaust further up the stream more quickly down the pipe.
I had a 4" straight pipe on my 6.0L, the engine noise was amazing, and the turbo whine was glorious. I really miss that setup. However I'm not touching anything until the warranty is up. My brother in law got hosed by Ford for not having the stock tail pipe on. His DPF system failed under warranty and they blamed it on him not having the stock intercooler tip installed. He could've fought it with a lawyer, but it would've probably cost more than the $1700 repair to the DPF system.
It sucks, but I'm just gonna have to live with stock for a while.
Old Sep 21, 2017 | 03:55 PM
Blwnsmoke's Avatar
Blwnsmoke
Umm.. it isn't straight piped, you replaced the resonator lol.
