Engine detail
Old Sep 18, 2017 | 07:03 PM
junorris's Avatar
junorris
Engine detail
Have any of you cleaned/washed the 6.7 diesel engines in these ....I use to use engine bright or something and sprayed my 6.0 with no problems....around here I get sand build up and like to keep the engine looking good too.
Old Sep 18, 2017 | 08:07 PM
Ricohman's Avatar
Ricohman
Dirt and dust won't hurt the motor.
Water will though.
If you really want too, cold engine, low pressure hose.
Old Sep 18, 2017 | 08:40 PM
UGA33's Avatar
UGA33
I clean mine every month or so. Spray the cold engine while avoiding the PCM pigtails,fuse box, and alternator with a ton of water. Usually spray a light coat of degreaser on a wet engine and let it sit for 30 seconds then rinse. Have done this on all my diesels. Never an issue. A clean engine bay makes me happy!
Old Sep 18, 2017 | 09:06 PM
MrFord619's Avatar
MrFord619
Modern engines are designed to withstand a certain amount of water. I highly recommend following this guide if you plan to wash your engine. I used the same process and all I have to say is wow. https://youtu.be/PRSoRkM8GcM
Old Sep 19, 2017 | 04:49 AM
junorris's Avatar
junorris
Thanks for the replys
Old Sep 19, 2017 | 07:14 AM
First Dually's Avatar
First Dually
Engine compartments are rather hostile environments. Way more so than what comes out of a garden hose.
Use common sense...avoid pressure washers and strong chemicals. Maybe even cover the alternator, fuse panel...
To be really safe, use a spray bottle of rinseless wash with brushes, and towels. Works really well if the engine compartment is not very dirty.
Old Sep 19, 2017 | 08:31 AM
shortride's Avatar
shortride
What ever you do it's generally not a good idea to power wash your engine while it's hot.
Old Sep 19, 2017 | 08:44 AM
HRTKD's Avatar
HRTKD
I've used this stuff a couple of times and I will never use it again. The nasty smell lingers for a very long time. AMSOil makes a citrus based degreaser that smells great and it is about as effective as the Gunk. Unfortunately, it's way over priced.
Old Sep 19, 2017 | 09:04 AM
1956Fatfenders's Avatar
1956Fatfenders
While I haven't had this one long enough to get engine bay dirty, on previous vehicles, I'd spray the engine compartment with a gun style hose nozzle adjusted to "mist" rather than "stream", and just rinsed the entire engine bay down, avoiding fuse boxes and the alternator. Then I'd use my leaf blower to blow as much dry as possible, start the engine briefly to dry belts and pulleys, and toweled the rest. Lastly, I'd take it for a short drive to cook off any remaining moisture. Never had an issue.
I would think modern 4WD vehicles would be designed to handle more than the average "paved road water" splashing up into the engine compartment, so I'm not concerned about washing the engine bay. This is basically what I do:
How to Detail Your Engine Bay | Ask a Pro Blog
waumpuscat
Jun 18, 2014 12:23 PM
gmcbride
Apr 12, 2011 06:00 PM
dlf
1983 - 2012 Ranger & B-Series
Dec 17, 2004 09:44 AM
Champ
2004 - 2008 F150
Nov 29, 2004 10:31 PM
Red_EB_Bronco
Offroad & 4x4
20
Jun 24, 2003 11:23 AM
