200,000 - Preventive maintenance
Old Sep 29, 2017 | 09:52 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
With conventional it is around 100,000 miles.
With ELC it is around 500,000 miles...
If you properly flush all that old coolant following the Gooch guidelines, you will eliminate the need to flush at later dates if you put ELC in. Once you eliminate the silicates, you eliminate the main reason for needing to flush in the first place (silicate drop out).
Old Sep 29, 2017 | 10:02 AM
unleashd's Avatar
unleashd
Yes. I will be following Gooch's guide for this. Shell Rotella ELC concentrate - 6 gallons ordered.
Old Sep 29, 2017 | 10:07 AM
andym's Avatar
andym
You only need four gallons of ELC to do the proper flush. You will need about 20 gallons of distilled water though.
Old Sep 29, 2017 | 10:52 AM
unleashd's Avatar
unleashd
I know about the 4gal need. Just that Amazon has the 6 x 1gal pack. I just ordered that
Old Sep 29, 2017 | 10:55 AM
unleashd's Avatar
unleashd
Any recommendations for the transmission oil?
Old Sep 29, 2017 | 11:17 AM
andym's Avatar
andym
Maxlife ATF multi-vehicle formula (includes Mercon V). It's not licensed by Ford but is known to be a good transmission fluid in the 4R100. Wal-mart also sells Supertech (wal-mart) Mercon V which is supposed to be good.
The best is probably Mobil 1 synthetic Mercon V but it's expensive when you consider that these things take about 20 quarts of fluid to do a full change.
Old Sep 29, 2017 | 11:29 AM
unleashd's Avatar
unleashd
https://www.walmart.com/ip/Super-Tec...d-1qt/17134874
Is this the right one? Walmart is next door to my office. I can walk over and pick up I do plan to swing by later to pick up the distilled water from Walmart.
Old Oct 4, 2017 | 09:39 PM
unleashd's Avatar
unleashd
Work-Parts-Cost Tracker Created
Old Oct 5, 2017 | 11:50 PM
agsmv1's Avatar
agsmv1
I use Shaeffer's, if its good enough for BTS it is good enough for me!
Old Oct 6, 2017 | 07:41 AM
mecdac's Avatar
mecdac
Lightbulb On the other hand
^^^^^ All excellent tips from: Art, Andy and Mike. ^^^^^
1. Pop open every trim piece and re-tighten:
Oh s hit bars / grab handles
"A" pillar handles
Rear door/hatch handles
2. Replace any missing trim cover pieces on aforementioned handles.
3. Torque down the Transmission Shift assembly
4. Replace the Multi Function Switch (headlight/dimmer, turn signal, wiper, emergency flasher).
5. Replace the
Brake pedal cover Brake pedal cover
6. Start saving for new fuel injectors necessary between 275,000 -325,000 miles approximately $1700-$3000.
7. Replace all bulbs behind the gauge cluster
I'm sure there is something else I forgot.
Old Oct 6, 2017 | 10:39 AM
agsmv1's Avatar
agsmv1
One other thing is to upgrade all the interior lights to led's. You would be amazed how hot the original ones are. Most of my light sockets suffered from high heat and some even had burn marks!!
Old Oct 6, 2017 | 01:48 PM
unleashd's Avatar
unleashd
Art
This is on my list to-do. I need to search look for a comprehensive list of bulbs that need to be procured.
Old Oct 6, 2017 | 06:23 PM
  #28
agsmv1's Avatar
agsmv1
Art
There is a pretty good guide in the tech folder. I used one of them. Then just shop around. Or you can even go to most sites and just punch in your vehicle and they will provide the correct ones.
Old Oct 9, 2017 | 04:22 PM
  #29
BleackBeast's Avatar
BleackBeast
Get a second mortgage while you're at it... I mistakenly tallied all the money I've spend on my Ex - it was a really bad idea. Not bad to spend it, just bad to tally it up
Old Oct 9, 2017 | 04:56 PM
  #30
mecdac's Avatar
mecdac
How much was maintenance?
How much was a necessity?
How much was an upgrade? A want not a need?
How much was bling?
Divide the number by a PSD/SUV vehicle payment (a new PSD/SUV would cost between $65,000 for an XL and $85,000 for a Limited or Lariat if not more) $1300.00 - $1800.00 monthly payment.
narrowfarm
Jul 28, 2022 08:31 PM
unleashd
Dec 10, 2016 03:51 PM
SunBum
Jul 27, 2011 12:44 PM
CEP
Sep 28, 2006 04:46 PM
dagren99
Dec 28, 2004 08:18 PM
