Fuel System Picking up Air
Old Sep 18, 2017 | 02:37 AM
Dean8020's Avatar
Dean8020
Hi all,
Just after a couple of new ideas, as I can't track down my air leak.
'66 F100 with in cab gas tank.
When the tank is below 1/2, there starts to be a small amount of air getting into the fuel line. (Can see it bubbling in the filters, and get misfires and stalling).
Have done a temporary run of new fuel hose from the 'hockey stick' under the cab to the electric fuel pump (new).
The filters are between the new electric fuel pump and the carb, with all new hoses and clips.
This long rubber hose made no difference, so the old hardline is good.
The unions into the tank pickup look clean, and the pickup pipe isn't rotted.
As an example, yesterday I went for a 20 miles run, and it ran fine.
Got home with just over 1/2 showing.
When reversing back into it's space it gets tipped passenger side down on a hill, and it sputtered, backfired a few times and stalled. It then wouldn't start and kept back firing (still on the hill).
Pushed off the hill back onto the flat and it fired up fine and ran normally.
Can't think of anything I haven't checked for splits!!
Old Sep 18, 2017 | 03:09 AM
Tedster9's Avatar
Tedster9
Just to be clear, all the rubber hose has been replaced to include the the short section under the drivers side cab, along the frame? Sure there aren't any pinholes in the pickup tube? Had the same problem in my '64, never did really determine what the fault was. It would shut down at half a tank like clockwork.
Old Sep 18, 2017 | 04:47 AM
The Masked Rider's Avatar
The Masked Rider
Small pin hole in the metal pick-up tube in the tank.
Here is how to locate hole in metal tube. Runs good till you reach a certain level of fuel and starts sucking air - right. If you have not yet put more fuel in the tank, remove the float assembly. Take a stick a couple feet long and slowly slide the stick into the tank till you reach the top of the fuel. You will most likely need a flashlight to see into the tank.That is also the depth on the metal pickup tube where the pin hole is. Sometimes it is hard to find a very tiny pin hole that is sucking huge amounts of air.
Old Sep 18, 2017 | 04:48 AM
User 71024's Avatar
User 71024
how do you know the pickup tube in the tank is good? Is it removable?
Old Sep 18, 2017 | 08:46 AM
Tedster9's Avatar
Tedster9
They aren't removable as such. It wouldn't be much trouble for someone handy to plumb in a new pickup tube.
Old Sep 18, 2017 | 11:02 AM
Dean8020's Avatar
Dean8020
So if it is a pin hole, is there a fix?
Solder over it, assuming it is steel?
Or can I sleeve it in something?
Otherwise I will need to look at shipping a replacement.
Old Sep 18, 2017 | 12:08 PM
Tedster9's Avatar
Tedster9
That's a possibility, overall how do the tank innards look though? Ended up replacing the tank on my truck. I could have rigged something up but overall didn't want to make a career out of cleaning the old tank out and the rest of it. Tanks are tricky to work with, gasoline fumes are no joke
Old Sep 18, 2017 | 02:33 PM
KO1960's Avatar
KO1960
Is pump below and as close to the tank as possible? Electric pumps are good pushers, but not good pullers.
Old Sep 18, 2017 | 02:43 PM
The Masked Rider
I remember some years back, someone was selling a thin walled plastic tube liner that would slide down into the existing pickup tube. Idea was, you remove the fuel line to the top of the tank, slide the liner in and replace the fuel line. The one end of the plastic tube had a flare to tighten up against the fuel line nut.
If you can find some thin walled tubing and you have access to a flaring tool, it might be worth a try for a short time fix.
At least you will know that a pln hole is indeed the problem.
Old Sep 18, 2017 | 05:21 PM
unibody62's Avatar
unibody62
Doesn't the pick-up tube come out with the float assembly? I'm pretty sure that's the way the were made. The screen is located on the end of the float/pick-up tube, correct?
Old Sep 18, 2017 | 06:32 PM
Tedster9's Avatar
Tedster9
Hm - could be, I don't know what year they were "modernized". The older units, the sending unit is all by its lonesome, the pickup tube is separate.
Old Sep 19, 2017 | 02:00 PM
Crop Duster's Avatar
Crop Duster
Fuel pick-up
Pick-up tube is part of the tank. It's spot welded and soldered in. And from what I saw when I converted my entire fuel system to 3/8 inch lines. It was installed before the two halves of the tank were welded together. It was a lot of work for not much gain. If you want to go that way I can post more detail of how I did it.
Old Sep 19, 2017 | 02:14 PM
unibody62's Avatar
unibody62
Okay, I guess now that I think of it, I assumed it was more like my '69 Tbird. It's been
a while since I messed with it and my project has not gotten to the point of fuel system.
Old Sep 20, 2017 | 01:35 AM
The Masked Rider
You might give this a try. Its made for those that wish to go to a modern fuel injection system but it also works with the stock fuel system. Just replace your stock float system with this one and cap off your original fuel pickup tube. PLUS, you get to run a larger fuel line to the motor. :O)
https://www.bobdrake.com/FordItem.as...b-566808f4ecf3
Old Sep 26, 2017 | 06:28 AM
Dean8020's Avatar
Dean8020
Hi all,
Thanks for the replies, and sorry for the delay.
Yes, All of the rubber has been replaced, including the short section under the cab.
This. I guess this means I don't know it is good afterall!
Anyone have any info on this? What diameter pipe should I be looking for?
I would like to prove it is the pickup pipe using this method before I go an import a new sender unit.
Cheers.
