1990 ford ranger 2.9 sputtering
Old Sep 17, 2017 | 06:27 PM
Paul Carey's Avatar
Paul Carey
Hello all.
I've become desperate for help. Im pretty lost at this point.. But some quick info about what my issue is..My truck seems to act as if its wanting to stall out or misfiring when I drive it. It usually begins once the motor is nice and warm ( normal running temp) . It idles fine. Also when its acting up the RPM's will surge back n forth.
I have done the following:
Replaced all Spark Plugs.
Replaced all Spark Plug wires.
Replaced Distributor Cap.
Verified Firing order is correct.
Replaced Coil Pack.
Replaced ECT.
Replaced Thermostat.
Replaced Thermostat Sensor.
Replaced IAC valve.
Replaced IAT Sensor.
Replaced Air Filter.
Replaced Fuel Filter.
Replaced TPS also adjusted.
Cleaned Throttle body and replaced gaskets.
Bought 6 new Fuel Injectors ( haven't installed yet )
Things I haven't done:
Take it to junk yard.
Run it into the lake.
Set it on fire.
Please help! Im lost and just dont know what else to check that would be causing this issue. its beginning to drive me insane
Old Oct 4, 2017 | 12:03 AM
blue_ranger's Avatar
blue_ranger
Have you tried SeaFoam or injector cleaner? I had a problem with my 88 where the O2 sensor wires were exposed after melting on the transmission. That made my truck run like crap.
Bodybag
1978 - 1996 Big Bronco
Jan 7, 2019 04:08 PM
mudslinger1979
Sep 17, 2007 07:21 PM
mattoney
Bronco II
64
Aug 10, 2007 05:14 PM
stupid red ranger
15
Jan 12, 2006 01:01 AM
ronsinmd
Jul 19, 2003 08:54 PM
