Adding DPF screen with FORScan
Old Sep 17, 2017 | 05:24 PM
saskowner's Avatar
saskowner
I just made the change to add the DPF screen and it appears to have done it successfully. I then opened the DTC screen and had it make a list of PID's. There are several listed with errors, is this normal or did something go wrong? Below is a screen capture showing the errors.
Gary
Old Sep 17, 2017 | 08:14 PM
UGA33's Avatar
UGA33
You are fine. Clear the log and they will all go back to none.
Old Sep 17, 2017 | 08:28 PM
saskowner's Avatar
saskowner
Thank you for letting me know. We are leaving on a trip tomorrow and I was worried that I had done something wrong.
Gary
Old Sep 18, 2017 | 08:14 AM
System's Avatar
System
Prolocutor
Every time I use Forscan, I will check DTC's before starting. There's generally one or two but they don't throw a light in the dash. Many/most will clear on their own in time but I clear them with Forscan while I'm in there. If you don't and they don't clear on their own after so many run cycles, then the CEL will illuminate. None of this is a result of using Forscan though...
2009kr
May 24, 2017 06:32 PM
rrcrum
2009 - 2014 F150
Mar 30, 2015 04:39 AM
oldfisherman
2009 - 2014 F150
Jul 10, 2010 05:17 AM
aquaman
2004 - 2008 F150
17
Oct 11, 2007 07:21 PM
