Dash Lighting
Old Jun 27, 2010 | 04:02 PM
oldfisherman's Avatar
oldfisherman
Question Dash Lighting
I just returned from a trip to Canada and I can't read the km/h on my dash. In fact if the sunlight is just right I have a hard time knowing how fast I'm going. When its dark and its lite up its fine but without the back lighting its very hard to read. Is there a fix for this?????????? Thanks.
Old Jun 27, 2010 | 04:07 PM
Chris Anchor's Avatar
Chris Anchor
Check your dash illumination dial next to headlights, it may be set to low for you to see. Just a thought, Chris.
Old Jun 28, 2010 | 07:35 PM
oldfisherman
The light doesn't come until its dark, I need to see it when its still light. Thanks.
Old Jun 28, 2010 | 08:27 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
Maybe lightly tint the driver and pass doors?
Old Jul 3, 2010 | 06:53 PM
bnk190's Avatar
bnk190
My truck does the same thing. It's the way it is. Only work around is to throw something over the sensor in the center of the dash to make it think it's dark outside.
I don't understand why the computer turns the lights off when the headlight switch is on. You would think that if I want the lights on I want them on not to be over ridden by the stupid computer.
Old Jul 4, 2010 | 09:12 AM
oldfisherman
Dash Lighting
Thanks for the reply. Have you discussed this with your dealer?
Old Jul 5, 2010 | 10:05 AM
bnk190's Avatar
bnk190
Yes - It's the way the truck is designed.
Old Jul 10, 2010 | 12:58 AM
Darshana72's Avatar
Darshana72
If dash illumination dial next to headlights are set to low for us to see it will create problem ?
Old Jul 10, 2010 | 05:17 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
No just spin it- its a dial. It will dim and brighten depending which way you spin it.
