4x4 header
Old Oct 15, 2017 | 06:56 PM
Amphihauler's Avatar
Amphihauler
As near as I can tell my truck is running a set of these Dynomax 85066 headers now.
https://www.summitracing.com/parts/wlk-85066
They are rusted out and I'd like to replace them but these headers are out of production as far as I can tell. Look better quality than those cheaper Hedmans.
Old Oct 15, 2017 | 07:17 PM
Amphihauler
One more I just came across.
https://www.summitracing.com/parts/big-12542flt
Old Oct 15, 2017 | 08:41 PM
1972RedNeck's Avatar
1972RedNeck
If you concerned about cost, build a set yourself. Otherwise, pony up and buy the Sanderson's.
Just my two cents.
Old Oct 15, 2017 | 09:29 PM
Amphihauler
Just my two cents.
I hear you. Not trying to be cheap I’m pretty sure now my current rusty headers are the flowteck two piece ones I posted above. Mine are shot with pin holes and I know they need to go. I’m hoping they will last until I make some other upgrades to the truck. I don’t want to replace them with the same ones until I can confirm the high pinion dana 44 I have will clear it. I’m fairly sure it won’t but want to check with the rusty ones in place before I change to something like the Sanderson. I’m still not sure if those will clear the high pinion either with the output in the center so I’m hoping to do the axle swap first so I can at least run the exhaust down and around the axle.
Old Oct 16, 2017 | 10:59 AM
Amphihauler
Are there any issues with the starter clearance with that Sanderson header on a 65 352?
Old Oct 16, 2017 | 12:57 PM
Amphihauler
I've got a set of Sanderson headers coming.
Old Nov 9, 2017 | 12:22 PM
derekxj's Avatar
derekxj
Did you end up installing these? How did it go? Also - which ones did you purchase the block huggers or the standard ones?
Old Nov 9, 2017 | 12:29 PM
Amphihauler
I bought them used on Craigs list. Not sure but I'm guessing block huggers? I haven't had a chance to install them yet but I did look things over close and I think they will work. The passenger side will go over the top of the starter it looks like. Seller said these were used on a mid 70's 4x4.
Old Nov 9, 2017 | 01:52 PM
Amphihauler
As near as I can tell these are the Sanderson FF394-p headers for a 61-66 T-Bird. For the price I had to give it a try. They do appear to follow the factory manifold locations and tuck in close to the block. Not sure if these would work on other applications but with my early frame style 4x4 with the leaf springs and single front engine mounts and dual bell housing mounts I think they will. Anyone else tried these?
Old Nov 9, 2017 | 05:19 PM
Rgak1964's Avatar
Rgak1964
I'm interested in seeing if these work. I have a 63 and 64 4x4 and looking at headers/manifolds for those. Why not go with ramhorns from mummert?
Old Nov 9, 2017 | 05:21 PM
Rgak1964's Avatar
Rgak1964
NVM, I figured out that you have a 352 and mine are 292 Yblocks.
RattyFord
Dec 6, 2018 02:11 PM
Amphihauler
Jun 24, 2016 09:10 AM
2zwudz
19
Oct 27, 2013 07:40 PM
2Hick
Feb 9, 2012 06:22 PM
jowilker
Sep 22, 2000 09:20 PM
