Should I run away and keep looking?
Evening everyone,
I was just looking at an 09 Sport Trac Adrenalin, and I found that the coolant bottle was full of build up for lack of a better word, and the coolant smelled a little like burnt rubber...
Here is a pic of what it looked like:
There were also some indications that front end works was done as there was overspray from a not so good repair shop.
While I can look past the overspray, should the bottle residue and who knows what else I am missing scare me away?
I am thinking I should keep looking, but I am also curious if I am over reacting.
Thanks!
Thanks!
Anything in the tank has to be added from the outside.. Inside "leak" would be motor oil or trans fluid...... I would guess this is some type of block / head gasket sealer. Should be poured into the top radiator hose if needed...... looks like someone dumped it into the tank ...... I would guess a repair "fix" was done for a head gasket leaking.
Anthony Bauwens
11-14-2016 12:10 PM
Dale Cooper
06-06-2014 11:16 AM
kedwinh
20
08-02-2012 04:30 AM
