1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Another EGR (Check engine Light) question
Old 09-16-2017, 04:31 PM
smithmiked's Avatar
smithmiked
smithmiked is offline
Just bought a used 2006 F250 only 85k miles and in great condition. shortly after purchase check engine light came on. Ran a code and got the EGR P0402 code. Replaced the EGR valve, next day, light came back on same code. Reset the code then hooked up my camper, light never came on while pulling the camper. as soon as I disconnected, Bam.. lights back on, cleared the code, hooked back up to return home, no light. 10 mins after disconnecting camper, light is back. I pulled the EGR valve and it's clean as a whistle. Was told using a Ford part versus a OEM would most likely fix the issue.. Engine runs great, no smoke in exhaust, plenty of fluid in reserve, getting 17MPG in city.. Any help would be greatly appreciated. I'm ready to just pull the light!!!
Thank You!
Old 09-16-2017, 07:51 PM
KULTULZ's Avatar
KULTULZ
KULTULZ is offline
Post
EGR P0402 code
That code does not identify the actual valve as the culprit. It only points you to a failure in that circuit. You then go through a diagnostic sequence to find the problem.
Old 09-21-2017, 03:21 PM
smithmiked's Avatar
smithmiked
thanks Kultulz.. I guess I'm more puzzled by the fact that I don't get any indications or the check engine light while I'm pulling my camper but as soon as I unhitch the light comes on within 10 mins. Was hoping somebody might have had the same issue and would share.
metal7654
1997 - 2003 F150
05-22-2010 12:17 AM
Texan58
06-23-2008 04:43 PM
hyeit54
1997 - 2003 F150
09-13-2005 10:33 AM
breedlrs
01-20-2004 05:41 PM
sbutler
3.8 & 4.2L V6
01-18-2004 07:49 AM
Quick Reply: Another EGR (Check engine Light) question
