Front Hub Assembly Question
Old Sep 16, 2017 | 02:44 PM
jacecil082's Avatar
jacecil082
Have an 06 2WD Navigator. Does anyone know if the bearings inside the front hub assembly are tapered or not. I believe there are two (inner and outer)? Are these also known as the axle bearings?
Old Sep 17, 2017 | 09:46 AM
alloro's Avatar
alloro
They're know as wheel bearings, axle bearings are inside of a housing like seen with a solid rear axle housing. That aside, your vehicle uses hubs and is replaced as an assembly, you cannot replace just the bearings.
Old Sep 18, 2017 | 09:52 AM
jacecil082's Avatar
jacecil082
Thanks for the info. That would explain why I am only finding the full assembly available when searching for replacement parts.
big native
17
Jan 7, 2014 11:21 PM
jollygreen_giant
15
Dec 8, 2010 12:38 PM
shu5720
May 18, 2008 10:10 PM
Wakeboarder141
1978 - 1996 Big Bronco
15
Nov 24, 2004 06:55 PM
toyota1988
Oct 8, 2003 10:39 AM
