Generators
Old Sep 21, 2017 | 03:31 PM
HRTKD's Avatar
HRTKD
My Onan 5500 mounted in my toy hauler had the exact same decibel reading as my brother's dual Honda 2k generators that were sitting on the ground. I measured from equal distances. That surprised me. I thought my Onan would come out a bit higher (louder) on the scale.
Old Sep 21, 2017 | 04:34 PM
RV_Tech's Avatar
RV_Tech
The hardest thing about measuring decibels is not only comparing by distance, but also load.
Lots of comments in this thread about inverter gensets being quieter, which is not automatically true. Inverter gensets running at their max are often quite loud.
Steve
Old Sep 21, 2017 | 05:30 PM
HRTKD's Avatar
HRTKD
In my case, both trailers were running a single air conditioner unit.
Old Sep 21, 2017 | 06:02 PM
RV_Tech's Avatar
RV_Tech
It's funny how sounds can seem louder or quieter depending on the frequency. We were just camping the last two days in the National Park near us and with lots of folks running gensets. A class C was running its Onan and man did it seem loud. But then again, our Yamaha sounds really quieter until you make it work at its max, then it doesn't sound so quiet.
And I have yet to hear an open frame that sounds quiet. Man, I really wanted some armor piercing rounds for some of the folks with contractor models camped near us!
Steve
Old Sep 21, 2017 | 06:20 PM
Tedster9's Avatar
Tedster9
Don't let anybody kid you, the Honda EU series for example are quieter than the cheapies but not exactly quiet. I can see where generators would become an issue in parks and campgrounds, especially at night. Hearing those things drone all night?
When they claim 59 db what does that mean exactly, 100 feet away, upwind?
Old Sep 21, 2017 | 06:32 PM
HRTKD's Avatar
HRTKD
I could be wrong but I thought that the standard measure for decibels was at 1 meter away from the source.
I have the Gen-Turi stack on my generator. It does a very good job of redirecting the exhaust fumes. It also helps a bit on the noise too, but that's not why I bought it.
Old Sep 21, 2017 | 06:49 PM
RV_Tech's Avatar
RV_Tech
Here is what the standard is supposed to be "Generators must conform to National Park Service regulations pertaining to audio disturbances, which states that "motorized equipment or machinery cannot exceed a noise level of 60 decibels measured on the A-weighted scale at 50 feet" (36 CFR 2.12)."
Of course, since the standard is never enforced, in reality there is no standard! If I were king here is what I would do. If you were in a National Park or National Forest, where the standard is supposed to apply, I would drive around and, with my trusty decibel meter, I would issue a one time warning to anyone with a generator that was louder than the standard. The next time it would be a $50.00 citation. On the third strike you would have to leave the campground.
Once word got out I think it would put an end to all the nonsense about $300 open frames being quiet. Unfortunately the notion of consideration for others is a long gone memory and some type of legal penalty strikes me as the only way.
Steve
Old Sep 21, 2017 | 07:01 PM
HRTKD's Avatar
HRTKD
60 decibels at 50 feet seems pretty doable. I'll have to check mine again at that distance. It does depend on what surface the exhaust is facing. Grass will muffle the sound some, but concrete sure won't.
Old Sep 21, 2017 | 08:08 PM
Forddiesel06's Avatar
Forddiesel06
Originally Posted by QMatthewG
I bought the Honda eu7000is generator. Runs both AC's and the TV and lights with no problem. It's on the expensive side but worth every penny. It's extremely quiet and you can literally hold a conversation while standing next to it.
Same here but mine is honda eu3000is and it is so quiet with making conversations.....
Old Sep 23, 2017 | 08:16 PM
2015F350's Avatar
2015F350
Originally Posted by scraprat
You could add one of these soft starts and your AC start issue will be solved. Go to the Airstream forum and there are alot of threads on these.
http://www.microair.net/collections/...nt=30176048267
Wow, Did not know that even existed. That would save me some cash for sure. Won't have to buy a new generator, Do you need two of them one for each ac unit (I have 2 15k units)?
Thanks,
Old Sep 23, 2017 | 08:31 PM
RV_Tech's Avatar
RV_Tech
Yes, you need one for each unit. Very simple to install and cheap to buy.
Steve
Old Sep 23, 2017 | 09:02 PM
scraprat's Avatar
scraprat
Top Answer: 5
Thanks,
There was a code "airstream" that would save $50, I dont know if its still good.
It gets a lot of good reviews.
Old Sep 24, 2017 | 02:10 AM
  #28
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Steve
$299 cheap to buy
Denny
Old Sep 25, 2017 | 06:33 PM
  #29
djousma's Avatar
djousma
Thanks for the lead. I just ordered a couple of these. The airstream coupon code is still good, although for $40 off each, not $50.
Old Sep 25, 2017 | 06:34 PM
  #30
djousma's Avatar
djousma
Steve
Steve, just ordered these. I'm pretty good with tools, but never opened up the a/c on the roof. Can you give the 10,000' overview?
Thanks, dave
