1978 - 1996 Big Bronco
Fixed that #$% starting problem
Old Sep 8, 2003 | 11:17 PM
Norm Carter's Avatar
Norm Carter
I don't post much here but I read up on the board sometimes. For the benefit of other Bronco owners: I had an intermittent no-start thing on my 86 302 TFI. Ran great but cranked longer than a well-tuned engine should before starting. Also every now and again it would just crank without any sign of starting. Shut the key off and 5 minutes later it would usually start right up. It was annoying and embarrassing! I got a code reader and didn't find anything real odd there but while running the KOER test I ran into the no-start thing. I immediately re-ran the KOEO code reader test and it wouldn't even activate the computer...dead! On a hunch I picked up a replacement EEC power relay for $15.00. The hard part was finding the old one (under the dash, clipped to the side of the EEC computer). I plugged in the new one and it now starts way quicker, and so far no more no-start problems. YAY!
Norm
Old Sep 9, 2003 | 12:47 AM
DW2455's Avatar
DW2455
man i wonder if thats part of my problem, did your do it all the time?, mine usually does it first thing, once its running its usually ok. ? DW
Old Sep 9, 2003 | 01:18 AM
oregonian's Avatar
oregonian
I'm curious also, but mine starts great after sitting for a long time, but warmed up it takes quite a few cranks.
Old Sep 10, 2003 | 09:42 PM
Norm Carter
Mine was intermittent, maybe once every week or two. Ran great once it ran, but every now and then it would almost start, then do nothing but crank, as if the rotor was not in the distributor. Lately it was getting more frequent, and twice lately it quit shortly after I began driving, then fired up after a few tries. I'd feel stupid telling you how many parts I replaced (but parts is cheaper than dealers usually). I can tell you I have shiny new ignition switch, distributor module (it really did go bad), fuel pump relay, fuel pump, fuel pressure relief valve, not to mention a cool digital code reader.
Old Sep 10, 2003 | 09:54 PM
DW2455's Avatar
DW2455
Well glad to know you got it fixed, stuff like that can be a major pain, but mines different, it always starts knock on wood! tap! tap! but it just dont want to fire right up first thing in the mornings, it wants to spinn a few times. ? Good luck with yours. DW
IHateCommieCars
Nov 11, 2016 03:36 PM
Pele
Modular V10 (6.8l)
Dec 13, 2015 10:28 AM
1977scoutii
Jun 5, 2015 09:41 AM
dnkensinger
Mar 4, 2015 09:18 AM
kjrpgh
Jan 12, 2003 09:54 AM
