Tires Size
Old Sep 15, 2017 | 11:46 PM
Sergiobc98's Avatar
Sergiobc98
Tires Size
Well, I have a 2004 E-350 5.4L V8
The truck says 225/75R16 but it has 235/85R16, in a few months it will need new tires, my question is, hold the same or change to "original" size?
Old Sep 16, 2017 | 12:47 AM
Sam I Am's Avatar
Sam I Am
If it was mine I would use the original size shown on the certification label on the driver's door area. And make sure the tires you buy are load range E.
Old Sep 16, 2017 | 07:04 AM
Nothing Special's Avatar
Nothing Special
225/75-16 are 29.3" tall, 8.9" wide
235/85-16 are 31.7" tall, 9.3" wide
Like Sam, if it were me I'd go back to the stock size (which you can hardly find in anything other than load range E). But that is an 8% change in diameter which might be noticeable in your final drive ratio. It's possible that a previous owner thought it was geared too tall and tried to "correct" it. For instance, if you have 3.55 gears, then switching to the smaller tires effectively made them 3.84 gears. Personally I think the stock tires would be fine with 3.55 gears, but you need to decide what you think. And if your gears are any taller than 3.55 (I don't know that any taller were offered...) then taller tires might be a problem.
On the other hand, if you have 4.10 gears, then the smaller tires are giving you 4:43s, and the stock (larger) tires will probably be seen as an improvement.
Old Sep 17, 2017 | 08:13 AM
YoGeorge's Avatar
YoGeorge
Another popular size, and one that Ford used on some of these vans, and which a lot of 250/350 van drivers use, is 245/75x16. These are 30.5" tall, almost directly between the 2 sizes you mention, and give a good footprint and some more meat than the stock tires. (Most guys also really like Michelin LTX M/S's, which I loved on my E150 for all the time I had it thru 3 sets.)
I agree with Bob on the gearing. You can find a gearing chart and there will be a rear axle code on your door jamb sticker saying what the gearing is. I would be more inclined to use the larger tires if you have stiff gearing like 4.10 or something. Either the stock size or the 245/75's will give you more torque and more RPM's than the tires you have.
George
Old Sep 21, 2017 | 06:59 AM
jayro88's Avatar
jayro88
My '88 e250 stock size is the 225's, but I am running the 235's. The reasons I upsized mine was for visual rwasons and also to lower the revs at hwy speeds. My van has 3.54s, but a 3speed c6 trans.
As far as performance, I did notice my van was a little more sluggish with the larger tires but not terrible. I would check to make sure your speedo is functioning correctly. There are plenty of speedo/gps apps for a smart phone that will give you your speed so you can compare it to the speedo read out. If the speedo was not adjusted when the tires were upsized then your speed will probably be ready low.
Old Sep 22, 2017 | 02:41 PM
maples01's Avatar
maples01
I put 245/75R16 on mine, I prefer wider tires, it gets better traction, does fantastic in the snow.
Old Sep 22, 2017 | 02:42 PM
maples01's Avatar
maples01
It's an E350, one ton van, it better have load E tires on it!
Old Sep 22, 2017 | 05:38 PM
Nothing Special
Sam I Am, who I was agreeing with in the post you quoted, had just said that. I was just pointing out that he wouldn't need to worry much about it because he was very unlikely to find anything other than a load range E in the size tire that came stock on his E350.
Old Sep 22, 2017 | 05:40 PM
maples01's Avatar
maples01
I don't know about that, there are so many 16" tires now, you gotta be careful.
Old Sep 22, 2017 | 07:07 PM
Sam I Am's Avatar
Sam I Am
I read the original post as the stock size is 225/75/16 and there are lower rated tires than E in that size commonly available.
I guess one of us got that wrong.
I am a big fan of keeping stock size tires on my trucks which is still my recommendation in this case.
Old Oct 22, 2017 | 10:21 PM
ogarcia434's Avatar
ogarcia434
I have a tire question also; The tires on my 1996 E350 are dry rotted and need to be replaced. I have been thinking of going with 265/60R18 (E rated). I want a bigger footprint with a lower sidewall.
Questions:
#1 - According to the Tire Rack this size tire requires an 8" wide wheel. Will this tire/wheel combo fit in my stock van without rubbing the fender well or obstructing the steering?
#2 - Did Ford offer an 18" wheel with 8X165.5 bolt pattern. If Ford did I presume it was on a F250/F350, will the offsets work on my E350?
Thanks in advance for your help.
s120483
May 21, 2017 01:24 PM
91CavGT
30
Jan 23, 2014 01:22 PM
otis348
Mar 17, 2005 01:07 PM
buckskin
Jan 2, 2004 04:06 PM
93bigbronco
Oct 22, 2001 05:28 PM
