Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Need a shop vac that can pick up gravel
Old 09-14-2017, 11:40 AM
afinepoint's Avatar
afinepoint
afinepoint is offline
My old 4 HP Shop vac has done well over the years but can not pull gravel all the way into the canister. It stops part way down the hose. We are installing a patio and there are small piles of #27 here and there. Small meaning handfuls.
I have seen the commercial machines but have no intention of spending in the high hundreds or more.
Since my 4 Hp almost gets it I was wondering if the 6.5 Home Improvement store models might work.
Thanks
Old 09-14-2017, 03:47 PM
lariat97's Avatar
lariat97
lariat97 is offline
I have a Shopvac 6.5 hp. It picks up bolts and crap I never thought it could
Old 09-23-2017, 02:38 PM
Aftrmidnite's Avatar
Aftrmidnite
Aftrmidnite is offline
Craftsman vacs, hands down. When I did computer room service, we used them to pull Glycol out of piping and condensers for repairs. Have a 12 gallon one at work that's taken a beating, with no problems. Have a 16 gallon at home from 1999, but it won't take a bag. Bought a 12 gallon, so I could use a bag. Boiler cleaning company at work uses two 16 gallon Craftsman in series to clean our oil boilers, said it's amazing how much abuse they take. I've also have used the 16 gallon to pull river rock out of the grass that was misplaced from plowing after a snow storm.
Old 10-07-2017, 04:37 PM
afinepoint's Avatar
afinepoint
The 6.5 HP Ridgid does the job. It pulls up #27 gravel through grass.
Old 02-05-2019, 10:25 PM
kendall69's Avatar
kendall69
kendall69 is offline
Agree Rigid. I had a sewer drain that was filled with gravel down about 10 feet. I duct tapped a 2" PCV pipe tp the end of the hose and it sucked that drain clean of sand and gravel.
Old 02-07-2019, 04:06 PM
daveengelson's Avatar
daveengelson
daveengelson is offline
I have not kept up with Sears Craftsman tool status; having said that; installed a 75 foot retaining wall which consisted 8 individual 3' by 6' holes to set I-Beams in concrete however rains came in the interim leaving approx. 1 ft of dirt and drain rock at the bottom of these holes. The material had to be removed before the project could proceed and out of desperation decided to try my Craftsman 6 hp shop vac and found it sucked up all the mud and drain rock in a relatively short period of time, although did go thru a couple of filters.
Old 06-02-2019, 02:01 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,288 Likes on 2,444 Posts
Old 06-02-2019, 04:38 PM
kendall69's Avatar
kendall69
Pulling wire
I laid down 1000 feet of 2" Electrical PVC and need to pull wire through it. I put the VAC on one end used a plastic bag with a rope on the other end and sucked it all the way to the vac. Tied off the cable and then pulled that through. Some guys feed the cable through each 20' of the pipe by hand, piece by piece. The VAC is the way to go for long or even shorter pulls.
Old 12-13-2019, 01:06 AM
Willy Sunshine's Avatar
Willy Sunshine
Willy Sunshine is offline
Kendall - great way of pulling the cable!
lariat97
Garage & Workshop
85
03-29-2014 05:54 PM
maxtor
16
06-16-2009 04:51 PM
tjc transport
Garage & Workshop
23
01-10-2009 09:30 PM
Ford_Six
Garage & Workshop
34
11-03-2007 01:36 PM
78bigunns
General Automotive Discussion
19
01-17-2004 05:47 PM
Quick Reply: Need a shop vac that can pick up gravel
