rust rust rust rust rust!!!!!!!!!!!!!!!!
Old Nov 7, 2001 | 03:53 PM
colonel_sanders's Avatar
colonel_sanders
AAAHHHHHHHH!!!!!!!!
its everywhere!!!!
its un-stoppable!
things keep falling off!
does this happen often?
is it bad luck?
i have 2 other cars that are a few years older, and are not rusting to the extent that this is?
why?
Old Nov 7, 2001 | 04:39 PM
MustangGT221's Avatar
MustangGT221
What year is your vehicle? One of the main problems in serious rust at an early age is that the paint from the factory flakes, and water gets under it and has a hard time drying, so it sits there and eats the metal. I just broke a shackle because of rust and mine is just a 95. I have no rust problems now because I cleaned it all up and put Miracle Paint from Bill Hirsch Automotive all over the body and frame. It is a PERMANENT cure for rust when applied properly. My truck is 95% rust proof. Watch out for the wheel wells and the bottom of the tailgate on broncos. On the frame, Ford puts a kind of weird paint on, and after years it just sticks dirt to it. I thought I had some surface rust on the rear end of mine but when I put the wire brush to it, it blew right off. I didn't have a rust problem but i figured it would be easier to prevent it now then fix it later. Go to hirschauto.com for more info. It is the only paint that is not affected by anything. DOT 3 brake fluid is a paint's worst enemy, but does nothing to this paint, it's awesome.
95 F-150 2wd Extended Cab Eddie Bauer
4" Superlift Suspension
Gibson Cat-back on 300ci I-6
Ram Air-MSD Ignition-32 BFGs
Old Nov 7, 2001 | 09:33 PM
cpnhgnjnky's Avatar
cpnhgnjnky
CharlieLed
Jun 13, 2016 11:23 AM
mattymax
May 28, 2015 08:23 PM
SuperDuty93
Jun 27, 2012 12:10 PM
93f250-44cepeks-olf-olf
Apr 22, 2006 03:35 PM
