Buying a 92 ford extended cab...
on
1 Post
not a crew cab right?
if so, the ext cab has an unusable seat unless you are 4. There are kits to raise it making adults able to use it. good for luggage tho on trips. wish I had an LWB EXT all those F150 years I had, we went thru a lot of black trash bags wrapping our gear, which added up when we went riding atvs most weekends of the year...
rust will be your enemy. frame ends, rear spring shackle mounts, floor plate near emergency brake cable, and the ultra common wheel wells
the engines will be damn near bulletproof. AODs the same every year, the E4 troublesome until 93-on
ralf
03-15-2007 03:58 AM
sbishop
11-19-2006 07:15 PM
