Running really bad.
Old Sep 11, 2017 | 06:24 PM
tcjhkbjt's Avatar
tcjhkbjt
Running really bad.
I have an 04 F2 50 with a 6.0 approximately 222,000 miles. All of the gauges on the dash look good all the data on the scan gauge looks good but it is running really rough. I filled up with gas last week and that's when it started. I'm hoping it's just bad diesel and not something else. What are some things I can do to try and clear it up At Times I can hear popping a little through the exhaust. Need some ideas.
Old Sep 11, 2017 | 08:03 PM
xcrsp440's Avatar
xcrsp440
Does it have any trouble codes?
Old Sep 11, 2017 | 08:26 PM
tcjhkbjt's Avatar
tcjhkbjt
No check engine light.
Old Sep 11, 2017 | 09:34 PM
packagerjr's Avatar
packagerjr
I'd start by replacing both fuel filters.
Program the SG for 'DTC Count' and, if any show up, you have codes that just haven't set the check engine light yet. Torque or ForScan good at retrieving those codes.
Old Sep 12, 2017 | 09:44 AM
tcjhkbjt's Avatar
tcjhkbjt
Ok I'll try that. I have the SCT tuner. Maybe I'll try useing it and see if anything comes up.
Old Sep 12, 2017 | 05:22 PM
navistarnut's Avatar
navistarnut
Need to scan for codes, just not having a CEL will not tell the entire story.
Does it also sound like it is popping through the air filter?
Cranks evenly or not?
Old Sep 12, 2017 | 05:49 PM
TooManyToys.'s Avatar
TooManyToys.
OK, so did you mean it accidentally got gasoline in the tank or just a slip of the tongue meaning filled the tank with diesel?
Old Sep 13, 2017 | 10:56 PM
tcjhkbjt's Avatar
tcjhkbjt
Can't really tell cause my truck is kinda loud already. Might be popping through the air cleaner. If so what do you think.
Old Sep 14, 2017 | 11:32 AM
navistarnut
Could be the sign of a bent push rod
scottddove
19
Nov 17, 2016 08:38 PM
blrman1962
May 26, 2007 07:15 AM
a1a5115
Jun 1, 2006 12:18 PM
East mountain 99
Jul 8, 2005 07:00 PM
