Engine light on.Truck running normal
Old Nov 11, 2016 | 05:47 PM
scottddove's Avatar
scottddove
Truck has been sitting a few weeks. Cranked it up drove 15 miles to town. Light came on as soon as I cranked it. Truck ran fine. I tried to pull the codes on torque pro no codes showed up there. Got out the AE and took a screen shot of the codes found.
When I try to clear the codes with the engine running the trucks stalls just a bit the engine light goes out for maybe a half a second and then comes right back on. Icp has no oil on the plug and has a pressure reading when truck is running. What should I be checking.
Old Nov 11, 2016 | 06:15 PM
coax9952's Avatar
coax9952
Do not pull or clear codes with the engine running...Key On Engine off....only. especially with AE...
Old Nov 11, 2016 | 06:16 PM
scottddove's Avatar
scottddove
Well already did it so now what?
Old Nov 11, 2016 | 06:19 PM
coax9952's Avatar
coax9952
Clear your codes, KOEO, rerun DTC, KOEO
Old Nov 11, 2016 | 06:22 PM
coax9952's Avatar
coax9952
Once you've flushed the Old files...then you start your truck, don't touch AE, Let it idle for awhile, the ses comes back on, then turn off the truck, reconnect AE, KoEo and download DTC
Old Nov 11, 2016 | 06:23 PM
scottddove's Avatar
scottddove
So koeo pull up codes. If there are any clear them? Light should go off? What do you mean rerun dtc
Old Nov 11, 2016 | 06:31 PM
coax9952's Avatar
coax9952
Your codes are "Diagnostic Trouble Codes" Your PCM puts them there because something is wrong. You can clear them, but they will come back if the problem has not been fixed. Because those codes may have been there for awhile, (not all of them will throw a code.)If you want the most current code, You have to flush them. Then pull a fresh batch....
Old Nov 11, 2016 | 06:38 PM
coax9952's Avatar
coax9952
Not to mention AE has access to over 700 sensors, all of which could throw a code. but they don't ALL throw a SES light......Making Sense???
Old Nov 11, 2016 | 07:01 PM
scottddove's Avatar
scottddove
Ok I flushed codes in koeo mode light never went off. Cranked let idle 5 min or so. Put back into koeo mode repulled codes all codes came back except the p0500
Old Nov 11, 2016 | 07:21 PM
coax9952's Avatar
coax9952
I'm still at work, so as far as reading tea leaves I don't have my book with me but you've got a start. The only one I can see to be worried about so far is the ICP sensor.
I'm sure one of the other crew will see this pretty soon and chime in....How old is your ICP?
Old Nov 11, 2016 | 07:25 PM
coax9952's Avatar
coax9952
Are you having electrical issues with your overhead console?
Old Nov 11, 2016 | 07:31 PM
scottddove's Avatar
scottddove
Icp is original 150,000 miles.
Old Nov 11, 2016 | 07:34 PM
coax9952's Avatar
coax9952
Hmmm, might be getting tired, If tugly sees this, he's probably gonna want to see some logs with the truck running. You're not having any issues right now?
Old Nov 11, 2016 | 07:37 PM
coax9952's Avatar
coax9952
Look at it this way..... At least your getting a heads up before something breaks. Might be something cheap..(I'm Dreaming now)
scottddove's Avatar
scottddove
No running issues. Idles fine. No oil in plug. Kind of weird right?
