Every glow plug code at the same time?
Old Oct 31, 2017 | 05:57 PM
Dr.Huxtable's Avatar
Dr.Huxtable
Ok I just tested all 8 plugs via the black and green connectors at the GPCM. Each one checks out 100%. Which is a relief, my harness must be ok and the plugs themselves are ok. Must be the GPCM. Some monkey lost the pink piece on the green connector in the past Looks like I had a two part problem.
Old Oct 31, 2017 | 06:14 PM
Per4mance's Avatar
Per4mance
I'm going through the same problem.have had a chance to look at it. I'm almost sure it's the controller.
Old Oct 31, 2017 | 11:06 PM
Yahiko's Avatar
Yahiko
The new truck did the same thing and I replaced the GPCM and
all was good and happy after that.
Old Nov 8, 2017 | 11:08 AM
Dr.Huxtable
We'll I'm happy to report that I am glow plug code free for several days now. I replaced the GPCM and the remaining 2 codes have disappeared
So to sum it up I did have a compound problem. Thanks for the help everyone
Old Jul 27, 2020 | 03:33 AM
Stroker 6.0 fan's Avatar
Stroker 6.0 fan
Post P0671
I recently got a P0671 code. It's been approximately 5 years since I last changed my glow plugs and harnesses. Since it isn't too expensive, I am going to change them again. I'm on the fence as to weather or not to change the module too, just trying to save some money. Any thoughts or suggestions? Thanks
och
May 31, 2013 07:22 PM
waterboy_fishing
May 25, 2013 08:23 AM
gporonsk
Mar 10, 2012 12:33 PM
truckeemtnfords
13
Dec 23, 2008 10:13 AM
jcp0003
Apr 1, 2008 02:31 PM
