Help
Old Sep 11, 2017 | 09:05 AM
brownsc's Avatar
brownsc
Help
I have a 1996 F350 crewcab dually. Two wheel drive. 7.3 PSD with 5 speed manual trans. 152,000miles. The truck has sat for about five years. Reason being my father went out one afternoon to drive it and it wouldn't start. His financial situation and health prevented him from doing anything to the truck so it just sat.
Last week he calls me and says come get it the truck fix it and it's yours, don't want to see it sit anymore.
So I pull the truck home. I put two brand new 850 CCA batteries in it. It cranks but will not start.
No wait to start light
No tach movement
No smoke from exhaust
No oil pressure gauge movement while cranking
No blown fusses under hood or in cab
Swapped around relays and fusses ( yes for the same amps )
Replaced CPS with grey one from AutoZone.
Fuel in bowl
HPOP resevor was empty. Filled it. Twice now it's staying full
Injector relay gets pretty warm
IDM on driver side inner fender gets pretty warm almost Hot to the touch.
Any suggestions or advice will be greatly appreciated. Funds are a bit tight right now and don't have the money to start throwing parts at it hoping.
Old Sep 11, 2017 | 09:22 AM
farmert's Avatar
farmert
How did you check the fuses, visual or a test light? Pay special attention to #22 and # 8 in the under hood fuse panel, as they power the PCM. Remove the IDM from the drivers side fender and give it a good shake while listening closely for water sloshing inside. I suspect the IDM is bad, as it shouldn't get that warm. Do you know anyone that has a truck with the 7.3 in it that you could try your IDM in it to see if it will start? If the other truck will start, that will tell you your IDM is good.
Old Sep 11, 2017 | 09:25 AM
Jarrett Campbell's Avatar
Jarrett Campbell
https://drive.google.com/file/d/0Byb...1qRU1VVGc/view
That should get you started. No WTS light indicates that the computer might not be working properly. Either it's not getting power or it is bad.
Double check fuse 22 with a multimeter, not just visually. Sometimes a fuse can fail and it is not apparent with a visual inspection.
Old Sep 11, 2017 | 09:27 AM
knottyrope's Avatar
knottyrope
use above flow chart to help assist you, also print it out and keep in glove box
Old Sep 11, 2017 | 10:41 AM
brownsc's Avatar
brownsc
Checked fuses with test light.
will the idm cause the tach to not move during cranking ? And oil pressure gauge not rise ?
Old Sep 11, 2017 | 11:16 AM
madpogue's Avatar
madpogue
IDM will not affect the tach. Oil pressure "gauge" on dash is not tied to any electronics. But don't look at any of that until you get that WTS on. You still have a main PCM power issue. Try disconnecting the fuel filter heater; a few people have had a no-WTS / no-PCM issue caused by the heater shorting, even though for whatever reason, the #22 fuse does not blow.
Old Sep 11, 2017 | 04:12 PM
brownsc's Avatar
brownsc
I disconnected the fuel bowl heater. Still no WTS light.
red wire with square black plug with small flat blade connector inside it.
brownsc's Avatar
brownsc
Gonna remove IDM now and inspect
Old Sep 11, 2017 | 05:16 PM
brownsc's Avatar
brownsc
Ok guys. Think I found it. I took the IDM out and it is over half full of water. Opened it up there is a few places on the board that the runners (copper strips that run to the components ) or whatever they are called are burned in to.
Thanks for all the help guys. Hopefully it didn't get the PCM too.
Old Sep 11, 2017 | 06:09 PM
madpogue's Avatar
madpogue
With the IDM disconnected, see if the WTS light is on now. That will at least provide some hope that the PCM has been spared.
Old Sep 11, 2017 | 10:16 PM
brownsc's Avatar
brownsc
Good news !!!
i think anyway.
Removed the IDM. It was literally over half full of water. Turned on the ignition. WAIT TO START light comes on !!!
Hopefully that means that the PCM is still good.
Gonna have hard enough time getting the IDM much less a PCM too.
Again. Thanks for all the help !! You guys are the best.
Old Sep 11, 2017 | 11:23 PM
madpogue's Avatar
madpogue
IDM is MUCH easier to source, since any IDM from a '94.5 to a 2003 will work. What's your general location? Maybe someone here who's nearby you has a spare IDM you can at least try out.
Old Sep 12, 2017 | 06:14 AM
brownsc's Avatar
brownsc
Rock Hill, SC
Old Sep 23, 2017 | 11:26 AM
brownsc's Avatar
brownsc
Waiting
Originally Posted by brownsc
Rock Hill, SC
I ordered a IDM. WAITING on it together here. I'll post a update when it arrives. Thanks again guys for all the help.
Northernroots122
27
Jan 2, 2019 09:52 AM
dmcgann
15
Jan 2, 2015 01:36 PM
Matthew Tate
19
Aug 15, 2013 07:43 PM
BLK 96
Jan 9, 2013 10:11 PM
bobbyt89
Jul 30, 2011 09:43 AM
