For purposes of clarification, the 1283 module is 6 volt correct? It's listed 49-53 Ford, so I'd think so, but. There's a guy at the FordBarn who has roasted three modules or somesuch, and thinking this might be why?
1281 is 12 volt.
No, the 1283 is for the 12volt flathead
1283P6 is for the six volt.
It should be OK, Pertronix doesn't want to see more than 8 amps through the primary circuit. 12V / 1.5 ~ = 8 amps. Bubba recommends using something like the blue Bosch coil, with an internal primary resistance of 1.5 ohms, and a ballast resistor, for a total of around 3 ohms. The ignition ballast in my slick has been bypassed for almost 20 years with a Pertronix I ignitor so I dunno.
I ran a dedicated ground wire from the distributor to the negative battery terminal and reinstalled Ignition #1, the one that has worked but runs rough. Did some cleaning and whatnot as well with the hopes of improving the the ground.
A meter across the + and - battery terminals fluctuates wildly while the engine is running, although this was not the case a month ago when I was checking the charging system.
It does not hold any voltage long enough the get a clear reading on a digital meter but best I can tell it fluctuates between 11 and 19 volts. Many, many times per second.
How old is the alternator? That sounds like a bad regulator, or worn brushes. Voltage spikes like that will kill electronics. That sounds like your problem.
Ted, just to clarify, Bubba recommends the Bosch coil that has 3 ohms internal resistance, with no external ballast.
Is your alternator feeding the battery directly, or is it connected under the dash like the generator was? I'd suspect a loose connection under the dash, if connected there, or a bad ground on the alternator case if not. 1-wire or 3-wire alternator?
edit: you aren't running alternator current thru a circuit breaker, are you?
