New member
Old Sep 10, 2017 | 07:13 PM
Wendelhiland's Avatar
Wendelhiland
New member
Hello all you Ford lovers. I have been a Ford man all my life, although the reason I've joined is not just to be among other right minded people. I need some help with a Ranger. It's a 2004 4x4 and I've put 240,000 trouble free miles on here. That is until two weeks ago.
I have an issue. She developed a loud rattle, and then on the way home started running really ruff, barely making it home. I pulled the engine, pull the front timing chain cover off, and sure enough, the plastic portion of the tensioner was gone and the chain had been loose and hitting the metal portion of the tensioner that remained. I then pulled the valve covers and turned the crank so the #1 piston was at the top, and the keyway on the crank was at top dead center, or 12:00. I then checked the slots on the cams to make sure they were parallel with the top of the heads. The right side is parallel but the left side looks to be at least a tooth off. How can this be when both cam timing chains, guides and tensioner are in tact? They both run off the jack shaft so how could one cam have jumped?
Also, the truck barely made it home. I
Can't see how, even with the loss of the tensioner, it would have caused the truck to run so poorly.
Lastly, from what I've read all 4.0 ranger 4x4s should have a balance shaft, but mine doesn't.
Need some feedback. I can't afford to replace all the timing components and reinstall just to find out the cams were correct, and by leveling the cam slots to the heads I screwed up the timing. I realize I've thrown a lot out there but any help would be greatly appreciated.
Joseph Gamble
New Member Introductions
May 15, 2019 06:32 PM
Dlogo0924
May 12, 2018 02:38 PM
bigtonefordguy
Jun 14, 2016 11:25 PM
dano1805
Jun 17, 2008 04:36 PM
merriem
Jan 3, 2007 10:50 AM
