Wheel well liners?
Old Nov 4, 2017 | 09:02 PM
  #31
Larrymac52's Avatar
Larrymac52
Originally Posted by NS70250
I ordered them on my 2018 F250. I drive on the beach a lot, and they should help with the sand/salt water splash.
I will be ordering in a month. My truck will get some work dealing with cattle in pastures and woods.
Definitely off road. Would you still equip your truck with well liners under these circumstances?
Old Nov 4, 2017 | 11:13 PM
  #32
TheLex's Avatar
TheLex
Are you folks worried that stuff will get behind the wheel well liners? I'm worried that hidden gunk like that could cause corrosion. If the well is open at least you can just hose everything off. Thoughts?
Old Nov 5, 2017 | 05:16 AM
  #33
rick danger's Avatar
rick danger
That was my concern as well. I was considering just getting the wheel wells sprayed. I finally just ordered the wheel well liners front and rear. Kind of decided I was worrying to much. Time will tell I guess.
Old Nov 5, 2017 | 06:25 AM
  #34
bushpilot's Avatar
bushpilot
i make the occasional pasture runs...my truck came w/ rear liners but did not have front liners (beyond the felt ones from the factory).
i added the front liners - it makes washing a lot easier....just use a garden hose to spray the cow **** off the liner and your done.
Old Nov 5, 2017 | 08:05 AM
  #35
Wes Hightower's Avatar
Wes Hightower
My truck came with rear liners and I installed OEM front liners. Not sure how much of anything can get behind them as they are a pretty tight fit but maybe it's possible. I like the finished look and wasn't too keen on that felt being exposed to the elements.
Old Jan 16, 2018 | 10:21 AM
  #36
Martin6's Avatar
Martin6
Originally Posted by 1956Fatfenders
https://www.amazon.com/HC3Z16F099A-F.../dp/B01N7JQ2WE
The plastic liners go over the felt liners.
Looking at getting a set of the front liners. Do the OEM front plastic liners cover more than the felt liners?
Old Jan 16, 2018 | 10:56 AM
  #37
1956Fatfenders's Avatar
1956Fatfenders
No. The felt liner is covered completely, nothing more.
Old Jan 16, 2018 | 03:16 PM
  #38
roadpilot's Avatar
roadpilot
Originally Posted by rick danger
Never did find out what grade aluminum they use. "military" grade is ridiculous. Just sounds good. Marketing nonsense. I'm sure the military specs different grades of aluminum depending on the properties they want for a particular purpose.
"Military grade" has NOTHING to do with how thick or what grade the aluminum is. Things in the military are designed to military specifications (mil specs). These specs are the design and standards. Mil specs is use to allow interchangeability between manufacturers. As long as something conforms to a mil spec, it should be exactly the same no matter which manufacturer made it. "Military grade" is nothing more than a marketing term when used outside of the military. It has no real meaning other than the way marketers say "tough" or strong".
Old Jan 17, 2018 | 04:13 PM
  #39
GABAR's Avatar
GABAR
.....Did you mean to say that your truck came with front wheel well liners and you installed the OEM rear wheel well liners?
Old Jan 17, 2018 | 04:33 PM
  #40
comptonbranch's Avatar
comptonbranch
I installed the Husky liners in the rear of my truck and they were a beast to put in. I had sore fingers for a few days. They fit very tight so i dont see how much of anything can get in behind or around them. They definately give a cleaner look.
Old Jan 19, 2018 | 07:36 PM
  #41
SouthernFryd's Avatar
SouthernFryd
I installed them because they make things quieter inside. Had several trucks with and without them and there is a noticeable difference.
Old Jan 19, 2018 | 08:15 PM
  #42
Buliwyf's Avatar
Buliwyf
My Husky rears didn't fit at all. Not sure what I'll do with them. Burn them, take pics, post pics for an eco-naut.
Old Jan 20, 2018 | 09:16 AM
  #43
Screamingbear's Avatar
Screamingbear
Worth it
I live in Michigan on a dirt/gravel road. Lots of mud in spring and fall, and lots of slop in a winter thaw. Lots of road salt in the winter.
I installed front, and rear OEM liners after delivery. I also installed Gaterback mud flaps at the same time. The install was slightly more difficult with the mud flaps, but very easy just the same.
I think the liners keep a lot of mud and salt from getting in all the nooks & crannies in the rear. The factory fiber front liners would be a disaster without the plastic liners. I would also have a lot of rock chips in the rear wheel wells without them.
I believe they protect far more than they could ever hurt, and they fit very tight. Not much of anything could ever get behind them. I would certainly get them again.
Old Jan 20, 2018 | 09:24 AM
  #44
Buliwyf's Avatar
Buliwyf
It looks and feels exactly like the aluminum on a M1101 trailer. If our new Ford trucks are THAT good, Ford can call it whatever they want. I'll be a Ford guy for life, if the trucks are that corrosion resistant.
Old Jan 22, 2018 | 12:17 AM
  #45
bigjeezy86's Avatar
bigjeezy86
I just did the rear liners. So much better looking! Since my truck is magnetic it look,that it just left a ****ty bodyshop. like half primer and half paint. And I didn't like all the folds from forming the wheel arch. Will order the fronts soon since they are plastic!
The felt are so hard to wash, even with a pressure washer , after 4 days of snowplowing with salt and road debris
