Wheel well liners?
Old Sep 10, 2017 | 06:53 AM
rick danger's Avatar
rick danger
Wheel well liners?
My next option question. I see alot of trucks without these. Not sure of their function. Do they quiet down the gravel noise on dirt roads? Do they give a nicer finished look? Will dirt and moisture become trapped against the metal? (salty dirt and moisture in the winter). Would it be better getting the wheel wells sprayed with bed liner? Maybe a couple thick coats would quiet down the gravel dinks, and keep the aluminum from becoming exposed from rock chips? Thanks for your input.
Old Sep 10, 2017 | 07:29 AM
MrFord619's Avatar
MrFord619
Quiet the gravel noise on dirt roads and protect the wheel wells? Yes
Do they give a nicer finished look? Yes
Will Moisture, salt and dirt become trapped against the painted metal? Most certainly
Spray wheel wells with bedliner? It will chip, ask me how I know.
Old Sep 10, 2017 | 08:06 AM
ElectronPlumber's Avatar
ElectronPlumber
Protects the wheel wells and gives a much cleaner, complete look in my opinion
Old Sep 10, 2017 | 12:10 PM
Shady Camper's Avatar
Shady Camper
I was going to Line-X, until I got the quote. Ended up using Huskey liners. Glad I didn't spray, didn't think of the chipping. I did mine to cover up the shody job Ford did in spraying the wheel wells.
Old Sep 10, 2017 | 12:30 PM
Oregoncattle's Avatar
Oregoncattle
I will leave mine without the liner. I travel gravel roads and want to easily clean behind the liner.
Old Sep 10, 2017 | 01:45 PM
xxxsherpa's Avatar
xxxsherpa
Same here. Maybe a few years down the road I'll address that issue. I like the clean look of them now.
Old Sep 10, 2017 | 02:22 PM
Oregoncattle
I have the rear wheel liners on my '13 F150. I have a F350 on order and will go without the liners this time.
Old Sep 10, 2017 | 02:25 PM
rick danger
Any particular reason?.....edit: sorry, saw your reason above
Old Sep 10, 2017 | 02:43 PM
Oregoncattle
I put the liners on the F150 because I liked the more finished look and wanted to protect the truck fender. The bed of the new truck is aluminum so it won't rust. I'm over the finished look and am all about function this time around.
Old Sep 10, 2017 | 03:41 PM
rick danger
In NY where i live they use a lot of salt in the winter. I hope I wont just trade rust for corrosion. Never did find out what grade aluminum they use. "military" grade is ridiculous. Just sounds good. Marketing nonsense. I'm sure the military specs different grades of aluminum depending on the properties they want for a particular purpose. Boats usually use 316 grade stainless for its resistance to corrosion from salt. Not sure the grade of aluminum that has the same salt resistance, but I'm hoping there's a little of that property in the trucks.
Old Sep 10, 2017 | 07:01 PM
Tom N OH's Avatar
Tom N OH
I had the wheel wells Rhino lined on my 2012. 5+ years & 63,000 miles later, no chips & no rust. My 2017 will get the same thing when it comes in. The Rhino is a softer material than the Line-X. Our trucks at work get the Line-X & things slide around in the beds, don't have that trouble with my Rhino.
Old Sep 11, 2017 | 12:13 PM
AMXDREAMER's Avatar
AMXDREAMER
I ordered front and rear on my Platinum (rear is standard). Easy to clean out with a brush and keep clean. It's very noticeable on the lighter coloured trucks when they don't have them.
Old Sep 11, 2017 | 04:31 PM
stewy604's Avatar
stewy604
I ordered my 350 Platinum SCSB with them (front and rear). Looks far more complete IMO. I'm diligent on removing them every few months to get any material build up out.
Old Sep 11, 2017 | 09:05 PM
acadianbob's Avatar
acadianbob
Yep, that's why I go Rhino Liner . . . .
Old Sep 11, 2017 | 09:47 PM
Notmeofficer's Avatar
Notmeofficer
I ordered mine with them.. cheapest insurance you can get..
Protects from chipping ..dirt crud in the seams.. rock and debris damage
I wouldn't consider a truck without them
They didn't come on my F150 and I installed aftermarket and it was a hassle
