clutch problem
Old Sep 8, 2017 | 07:13 PM
maltapaul's Avatar
maltapaul
clutch problem
Hi guys i have a 1997 Ford ranger with a 2.3 L 5 speed. I replaced the clutch about a year ago and installed a Sachs brand kit there is no problem except that it is harder to press than others. I replaced the clutch on my son's truck (same year ranger ) and used a Luk kit and it is much lighter to press. My truck takes 51 lbs to press the clutch pedal. Before I change my pressure plate again and since there are so many brands of kits out there, Does anyone know which brand clutch kits is the lightest to press the pedal? Just to let you all know there is nothing wrong with the clutch, master cylinder, slave cylinder or bleeding on my truck.
Thank you
Old Sep 8, 2017 | 10:34 PM
wtroger's Avatar
wtroger
LUK made a lot of the Oem clutches for Ford. They work well and I never had one that was hard to depress. If you used a Sachs stage II then the stiffness expected.
chilewolf79
Jun 2, 2012 05:24 AM
johnjx1
Oct 3, 2007 09:47 PM
1978fordf250
28
Jul 9, 2007 10:58 PM
Katmandu
Aug 27, 2004 08:46 PM
Jim in S. Tx
May 31, 2003 02:31 PM
