Directionals question
Old Sep 8, 2017 | 11:17 AM
bcamill's Avatar
bcamill
1983 F100 with 302. I had added two 12 inch fans to my condenser to assist it since I live in AZ. At times the directional will not work with the AC on. Just wondering if another flasher with less resistance is available or any ideas to correct it.
Old Sep 8, 2017 | 11:40 AM
ctubutis's Avatar
ctubutis
Does the problem happen at idle, or at speed? If at idle, I can see low alternator output/bad connections/similar contributing to the problem.
I would poke around the flasher connections with a voltmeter to see what sort of electricity is making its way to the fuse box, go from there.
Old Sep 8, 2017 | 11:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
TWO different flashers: Light duty unit for turn signals, H/D unit for 4 way flashers. H/D flasher has a louder CLICK.
Both flashers look identical, are round with two prongs.
The 4 way H/D flasher can be substituted for the T/S flasher and was for trailer tow, Camper Specials, dealers installed it for people that were deaf.
But you should not use the T/S flasher for the 4 way flasher, because it's a "weak sister."
Old Sep 8, 2017 | 01:21 PM
matthewq4b's Avatar
matthewq4b
Just go to a heavy duty electronic one that will fix the problem
https://www.napacanada.com/en/p/FLSHD12
or Tridon/Novita EL12
https://www.rockauto.com/en/moreinfo...120666&jsn=445
Old Sep 8, 2017 | 01:39 PM
bcamill's Avatar
bcamill
Thanks guys. I will try the suggestions
Old Sep 8, 2017 | 06:54 PM
Franklin2's Avatar
Franklin2
The original flashers work on heat. The heat is generated by the current going through the flasher to the bulbs. Anything that lessens the current, lessens the heat generated, and the heat is what makes it click on and off. Your lower voltage from the fans pulling the system down is lowering the current, and the flasher is not heating up to flash.
If you press on the gas pedal a little bit, see if it starts flashing. The electronic flashers and the heavy duty will probably fix it. The only good thing about the original light duty flasher, if a bulb burns out it will tell you by not flashing.
69oiler
Oct 29, 2017 08:11 AM
buttwheat
Sep 16, 2013 07:27 AM
cdnturbo
Oct 8, 2009 06:34 AM
884x4broncoII
Aug 23, 2008 01:24 PM
allwthrrider
Mar 1, 2008 12:41 PM
