Turn signal problem
Old Feb 29, 2008 | 12:55 PM
allwthrrider's Avatar
allwthrrider
Turn signal problem
Hey everyone hope you can help. I have a 2002 E350 motorhome I wired up to tow my Jeep but the signal was weak so I went to get a heavy duty flasher, I disconnected the flasher while turn signal was on and now I have no turn signals, I put old flasher back in and nothing, I have checked all fuses and fuses in distribution box all ok, emergancy works ok, Is there a fuseable link in the turn signal system and if so does anyone know where it's located or any ideas what is causing my problem.Thanks for any help
Old Mar 1, 2008 | 12:41 PM
allwthrrider
Found the problem,The circuit was supposed to be position 10 in the fuse box with a 15amp fuse, turned out to be position 7 and it had a 10 amp in it's place,
