Not sure what kind of RV you're dealing with, but if the Ford Escape if within the tow limits if your RV, there shouldn't be a problem. The RV should have trans aux cooler as required to fulfill the limits stated.
I'm not concerned about my RV. My concern is for the transmission fluid temperature in the 2011 Ford Escape toad. Is there an industry standard for safe range of fluid temperature?
There is no industry standard. Ford has a standard, though, as I assume each manufacturer does.
You can run the trans as high as 220°F all day long and not have a problem. You can go as high as 250°F for no more than a half hour at a time.
