408 build/tcase
Old Sep 7, 2017 | 08:43 PM
KingProvince's Avatar
KingProvince
408 build/tcase
I'm going all in on this 408 build and wanted to know what other people have done so if u have one or know of one could u drop some spec lists things u ran into as it went along and such...
​​​​​​​also my machinst said the standard bw1356 can't really hold the power of a 408 so does anyone know about that and if it's true or false and if so what they did about it
Old Sep 9, 2017 | 12:02 PM
Conanski's Avatar
Conanski
They put the same tcase in the HD trucks with the 7.5 big block and diesel engines. Now.. I kinda suspect that version of the case may have some beefier components inside, certainly some parts are different as there are versions with a PTO, but overall this is a robust t-case.
Old Sep 16, 2017 | 02:38 AM
BMW2's Avatar
BMW2
I agree that it's a pretty stout tcase although I don't know whether the 1 ton version was built any better either. That said, an np205 is about as strong as they get. Of course you'll need driveshaft mods to make it work and I don't know if your build is computer controlled and what issues that may cause. I say run it until/if it breaks before upgrading anything. What kind of rig are you building?
Old Sep 30, 2017 | 01:37 AM
SDDL-UP's Avatar
SDDL-UP
.... And you are building a 408 what exactly? Windsor, Cleveland, bored 400, FE?
SilverHighboy
Jul 12, 2010 10:39 AM
mando jake
May 5, 2007 11:32 PM
F150 hybred
21
Oct 17, 2006 10:28 AM
wclement7
May 8, 2005 01:05 PM
yukonhighboy
Oct 26, 2003 05:29 PM
