Sponsored by: Auxito
Camshaft position sensor harness.
Old Sep 7, 2017 | 04:10 AM
joejoebo's Avatar
joejoebo
Just bought a 2002 4.6 v8. Check engine light was on and it pulls code po340 for the camshaft position sensor. I took a look at it and found its not plugged up. The plug is missing but the two wires are still there. I can replace the two wire plug but does it matter which wire goes to which side of the sensor? Any help would be great. Thanks.
Old Sep 7, 2017 | 11:10 AM
alloro's Avatar
alloro
See if this looks like yours and if you have Light Blue and Dark Green wires.
Old Sep 7, 2017 | 01:18 PM
Bluegrass 7's Avatar
Bluegrass 7
You need this sensor operational because it controls fuel injection timing.
Good luck.
Old Sep 7, 2017 | 02:07 PM
joejoebo's Avatar
joejoebo
Yes. Thanks. Looks like mine.
Old Oct 27, 2018 | 03:59 PM
Oldawg's Avatar
Oldawg
Camshaft position sensor wiring
I had the same question. So glad to have found this!
just2dune
Feb 20, 2011 05:22 PM
JohnInBHM
Aug 12, 2007 08:48 PM
dogg16
Bronco II
Aug 17, 2004 12:11 PM
rgillies1986
Jun 25, 2004 01:56 PM
nmaineron
Mar 8, 2002 01:07 PM
