Newbie with cut O2 sensor wire question
Old Aug 12, 2007 | 07:34 PM
JohnInBHM's Avatar
JohnInBHM
Greetings from Birmingham, AL! I bought a '92 Explorer recently and it is throwing a "heated oxygen sensor - right side" error code. Runs rough on occasion and uses gas like it's going out of style.
I thought, okay, I'll replace the bad O2 sensor... I've been looking all over this 4.0 engine for the location of the bad sensor and can't seem to find where Chilton says they're supposed to be. Chilton says there should be one on each side at the manifold. Left side has one there but not the right. I did find one on the engine side of the converter and was certain it couldn't be that one because it only had two wires coming out of it.
After tracing the two wires to the plug, I found that two other wires were cut at the sensor end and at the plug end. If this is the one causing the error code, why would someone cut the wires from a 4-wire sensor to make it a 2? I was going to invest in a new 4-wire sensor, but if the original was cut to avoid a bigger problem, I don't know if I should. HELP!
Thanks in advance for your advice.
John
Birmingham, AL
Old Aug 12, 2007 | 08:48 PM
super 6.8's Avatar
super 6.8
You will want to replace it with the 4 wire part and splice the wires back together if they are on the harness side of the connector. I have never heard of anyone cutting these wires. Two are for heating and two for exhaust sniffing. It would definitely throw a code with the cut wires.
dchamberlain
Apr 25, 2023 11:18 PM
jerryrigged
1997 - 2003 F150
Apr 1, 2017 01:36 PM
EcoBooStang
2009 - 2014 F150
Aug 17, 2016 07:17 AM
SpartanDieselTech
Jun 21, 2016 01:44 AM
Legal Lariat
Nov 1, 2015 09:28 PM
