Replacement for stock "capped" lug nuts installed
Old Sep 6, 2017 | 07:45 AM
Robbgt's Avatar
Robbgt
Was time to replace the lousy oem capped lug nuts. I do my own tire rotations with an impact gun and many of the lug nut caps were cracking and distorting. I'm sorry, but you should be able to use an impact on truck lugs without issue - really unacceptable that this is what we were given.
Went with a set of Gorilla 61108CXL. Ordered from Ebay for under $100. They are solid steel (no cap) and tipple chrome plated. The look is very close to factory, they are maybe a 1/4" longer though it's not noticeable. Highly recommend them.
Here are some pics:
Old Sep 6, 2017 | 10:00 AM
Green Power's Avatar
Green Power
Those are sharp! I need to see if i can find a set of amazon, i have the capless nuts on my non bobcat wheels, and it bothers me.
Old Sep 6, 2017 | 10:56 AM
tractorboy924's Avatar
tractorboy924
I need to go get some of those!!! those OEM capped ones get all screwed up and stuck in my impact gun sockets!!
Old Sep 6, 2017 | 10:59 AM
Robbgt's Avatar
Robbgt
YUP! Hate the capped ones for the same reason.
This is the Ebay seller that I used though I'd shop around to see if you can get a better deal elsewhere: 24 GORILLA F150 14x2 OEM STOCK FACTORY WHEELS RIM XL LARGE SEATS LUG NUTS CHROME
Old Sep 6, 2017 | 03:19 PM
2jhanna's Avatar
2jhanna
Lug nuts do look good.
But, do you use the impact to install, at full torque?
Old Sep 6, 2017 | 03:36 PM
Robbgt's Avatar
Robbgt
My air impact has 3 settings, at setting 2 I am at ~130-140 ft-lb. I drive them on per the pattern in the manual with the impact then use a torque wrench to finish @ 150.
Old Sep 6, 2017 | 04:47 PM
06pghescape's Avatar
06pghescape
ROBBGT; Looks like you have these Gorilla 61108CXL F-150 Lug Nut Kit Bulge Chrome 2009-14/Raptor 10-14 | eBay . I put them on my truck back in March , some much better than the stock units
Old Sep 6, 2017 | 05:16 PM
2jhanna's Avatar
2jhanna
Ok, just scares me for install with impact, overtorqued. Nothing worse than being on the side of the highway and not being able to break lugs free with factory lug wrench.
And then having studs all buggered up from being too tight.
Old Sep 6, 2017 | 08:30 PM
Robbgt's Avatar
Robbgt
Originally Posted by 06pghescape
ROBBGT; Looks like you have these Gorilla 61108CXL F-150 Lug Nut Kit Bulge Chrome 2009-14/Raptor 10-14 eBay . I put them on my truck back in March , some much better than the stock units
Yes sir, same ones. Glad you're happy with them too
Hey, I'd do what you're comfortable with. If I didn't have an adjustable torque impact I'd probably be a bit more hesitant. Since I've tested it a bunch of times now I'm confident in the method.
Old Sep 9, 2017 | 11:17 AM
paredneck33's Avatar
paredneck33
Those Gorilla lug nuts are very good quality and look really nice. Well worth the money. Did you happen to get the adjustable length lug wrench with your lug nuts as well? It doesn't look like it would, but it actually does work really well.
Old Sep 10, 2017 | 06:23 AM
Robbgt's Avatar
Robbgt
I didn't, kit was only for lug nuts. I use an impact gun to remove/install the final torque with torque wrench. I have a breaker bar and 13/16 deep well socket that I keep in my truck box if needed roadside.
AMG-SM
Dec 25, 2012 01:34 PM
Hunt89
Jul 6, 2011 03:47 PM
notyettoday
Sep 21, 2009 11:11 AM
tworivers
Bronco II
Sep 7, 2004 12:33 AM
wheelnut
Jul 15, 2004 04:10 PM
