Rear End?????
Old Jun 10, 2001 | 02:28 PM
1965f250's Avatar
1965f250
Rear End?????
My friend has a 1993 F-150 and we are trying to figure out what rear end he has. My 1965 has a tag on it that says 4.10...pretty easy. The tag on his has the following;
S844B
55883E07
Thanks ahead of time for helping to decipher this.
Cheers, Brian
Old Jun 10, 2001 | 09:49 PM
crazy_goodolboy's Avatar
crazy_goodolboy
Rear End?????
Do you know if it's the original rear end? If so, what's the door jam axle code. I might have more of a chance of figurin that out than those crazy series' of numbers they put on em.
Old Jun 11, 2001 | 12:12 AM
ecarter50's Avatar
ecarter50
Rear End?????
If you go look at the tag again there is probably a 3 in the bottom left corner maybe under the bolt that holds the tag on which would make it a 3.55 ratio 8.8 inch differential.
Old Jun 12, 2001 | 11:37 AM
TallPaul's Avatar
TallPaul
Rear End?????
Door jamb code is listed in the owners manual in the towing section with the associated ratio. Also it never fails to count driveshaft turns while pushing truck one rear tire revolution on flat concrete. I believe the axel tag will have an "L" between the whole number and the fraction for locking rear end and some other letter for an open rear end. Based on that looks like could be 3.07, but I my F150 has a 3.08.
Old Nov 8, 2001 | 01:24 PM
fishmanndotcom's Avatar
fishmanndotcom
Rear End?????
my 1993 F-150 has a 3.55 with a locking rearend. Any questions e-mail me at RedneckCadet@Netscape.net
-Jason-
Old Nov 8, 2001 | 03:07 PM
cbremer's Avatar
cbremer
Rear End?????
Check the "how can tell if m tuck has a limited slip? " thread... good stuff there, lots of ways to tell, even if you cant read the tag, or if the tag is missing.
Chuck
Old Nov 8, 2001 | 05:46 PM
Pastmaster's Avatar
Pastmaster
Rear End?????
johnmel59
Jul 15, 2014 02:08 PM
sonny1965
Apr 17, 2014 04:26 PM
1965GTFB
Jun 27, 2013 12:12 AM
civicmindeddogooder
Jan 29, 2013 06:01 PM
Gene Stum
Jul 21, 1999 11:36 AM
