1969 F100
Old Jul 15, 1999 | 05:19 AM
Gene Stum
Guest
Posts: n/a
1969 F100
I recently purchased a 1969 F100 with the intent of restoring it. I was told by the prior owner that the engine was a 390. It also has a 4 speed transmission in it which I was told was from a 1965 Mustang and the rear end was from a 1966 Mustang. I am trying to confirm the engine size, transmission, and rear end but all of the identification tags are gone. Is there another way to ID these parts?
Old Jul 15, 1999 | 06:00 AM
Stock Man
Guest
Posts: n/a
1969 F100
Gene:
I have some info on my website which may help you ID your engine and tranny. The rear-end ID will be harder. If you need any help, just ask.
Stock Man
1967 Galaxie 500 Convertible (I need factory rims)
1967 F-250 FE 390 4wd
<a href="http://www.hometown.aol.com/tbeeee">http://www.hometown.aol.com/tbeeee</a>
Old Jul 15, 1999 | 06:06 PM
ole65's Avatar
ole65
1969 F100
Let's see, the largest V-8 engine in 65 and 66 Mustangs were 289s. And, except for Shelbys, the rear axles were 8 inchers. I wouldn't put alot of stock into the info you have to date. The easiest way to tell a 8 from a 9 inch Ford rear is if you can put an extended socket onto the bottom flange bolts. If you can, it is a 8 inch. If you can't (only can loosen the nuts with a box-end wrench), then it is a 9 incher.
Old Jul 19, 1999 | 05:35 AM
Gene's Avatar
Gene
1969 F100
Well ole65, I tried your test for identifying the rear end in my '69 F100. The extended socket fits on all of the bolts. Can I now absolutely confirm that it is an 8"?
Thanks for your help.
Old Jul 19, 1999 | 06:05 PM
ole65's Avatar
ole65
1969 F100
Yes and no. It is not a Ford 9 incher; but it could be an 8. Since it has been changed, there even is the awful possibility (but unlikely) of having a 7 1/2 inch axle from a six cylinder car. Horrors! I really didn't/don't know that Mustangs had the same axle width and spring perches as the pickups. But there are a number of Ford vehicles that it could have come from. Oh yes, one correction. 289 Hi-Po also had 9 inchers --- also rare. There is also the possibility (more likely to me) that someone stuck a non-Ford axle (Dana as an example) under there from a F150 etc. The way to tell those is an axle tag, stamping or get a manual with picture I.D.s of the housing cover (they have different shapes).
Old Jul 21, 1999 | 11:36 AM
Carl...old air parts
Guest
Posts: n/a
1969 F100
nobes1969
19
Sep 28, 2017 07:31 PM
V8TV
160
Dec 4, 2016 09:28 PM
Josh1767
Jun 30, 2015 05:11 AM
orich
Jul 2, 2014 08:21 AM
49ford
17
May 13, 2006 03:05 AM
