Erratic Tachometer
Old Sep 5, 2017 | 10:28 AM
tnab1970's Avatar
tnab1970
Erratic Tachometer
1989 f150 4.9,4x4, 5 speed.
Factory in dash tach. is erratic and sticks at certain rpms for several minutes. No rhyme or reason. Any ideas as to a starting point?
Old Sep 5, 2017 | 10:49 AM
Conanski's Avatar
Conanski
eradicate: to remove (something) completely : to eliminate or destroy
Congratulations for spelling it correctly but I suspect that isn't the word you wanted, I think you meant "erratic: acting, moving, or changing in ways that are not expected or usual"
I also suspect the tachomoter in your truck is faulty, it is pretty easy to change though so that would be my suggestion. You can do so by removing the trim around the dash cluster, then the clear lens over the cluster, and then the tack module will simply unplug from the cluster and you can insert another that you could source from a junkyard truck for example. I'd also suggest that you grab the whole cluster just in case the problem is with the PCB in the cluster.
Old Sep 5, 2017 | 12:56 PM
tnab1970's Avatar
tnab1970
I am a horrible speller : Yes I meant erratic, that is what i was going for when the dang spell checker thing through me off track. Crapp and I cant fix it either!
So, you think it is the tach and not a short somewhere? I had suspected a short in the harness????
Old Sep 5, 2017 | 05:45 PM
Conanski's Avatar
Conanski
I have seen other instruments in these clusters go nuts so the gauge itself would be my first suspect. Can't totally rule out a wiring problem either but I suspect the gauge would just go to zero or to max if there was an open or short circuit.
Old Sep 5, 2017 | 06:36 PM
Scndsin's Avatar
Scndsin
Originally Posted by tnab1970
.... Crapp and I cant fix it either!
Click on the edit button of your first post, then click "go advanced".
Then you will see the title bar & you can change it.
Old Sep 6, 2017 | 09:28 AM
tnab1970's Avatar
tnab1970
OK, we will head to the yard today at lunch see if we can locate a cluster. I will post the status when installed.
Old Sep 6, 2017 | 12:58 PM
katjtodd's Avatar
katjtodd
Pull you tach module out and look at the soldered connections. If you notice any connections that look dull and oxidized clean and resolder them. I have fixed several of ford tachs this way.
Old Sep 6, 2017 | 06:06 PM
tnab1970's Avatar
tnab1970
If replacing the Tach does the donor vehicle have to be same engine?
Old Sep 11, 2017 | 07:50 AM
tnab1970's Avatar
tnab1970
OK, so I replaced the Tach with a used unit. Works just as it should. Thanks for the help everyone.
BaldEagles&Freedom
13
Dec 28, 2018 07:44 AM
eatont9999
Feb 3, 2012 12:33 PM
kylekip68
Nov 18, 2004 06:20 PM
gene79
Jul 27, 2003 08:31 PM
bos3kd
Jul 14, 2003 11:27 PM
