Install new cluster with tach
Old Jul 27, 2003 | 11:55 AM
gene79's Avatar
gene79
I have install a new cluster with tach in my 1996 ford F150 with a inline 6, the cluster was out of a 1992 , my problem is the volts gauge is peged . what is the fix on this , do I need to add a resistor if so where and what size.
Old Jul 27, 2003 | 12:04 PM
pfogle's Avatar
pfogle
I would first check and see what the voltage is at the battery when the truck is running. It may just be that the regualtor in the alternator died and the gauge in your dash is correct.
Old Jul 27, 2003 | 08:31 PM
brown 4x4's Avatar
brown 4x4
The wiring for the voltmeter on the cluster changed sometime between those years. Your truck probably isn't charging now either. You'll have to compare the two clusters and maybe wiring diagrams, but IIRC it's not too hard to make the older one work in your truck.
