Maintaining Dump Trailer Battery
Old Mar 15, 2008 | 02:02 PM
Beast12's Avatar
Beast12
Question Maintaining Dump Trailer Battery
Well, we just picked up our first dump trailer yesterday. We got a BigTex 10SR: http://www.bigtextrailers.com/trailers/10sr.html
We have a couple trucks at work that we will be pulling this with. I am not sure I want to spend the time wiring up a trailer charge wire (although I may do it). I was wondering about those solar chargers. Would one of those work good for this?
The dump feature uses battery juice for putting the bed up as well as down. When it gets used to dump it would only be 1-5 times per day (if that) when it does go out. A lot of times it will just be used to transport our skid steer around.
Any info would be great.
-Matt
P.S. Does anyone have a REALLY good diagram for a trailer charge wire for a truck that doesn't even have one set up?
Old Mar 15, 2008 | 03:39 PM
mudmaker's Avatar
mudmaker
I dont see why a solar setup wouldnt work quite well. I dont have a dump trailer myself, but a friend of mine has a couple about the same size you are dealing with that I borrow on occasion. Both of his dont use power coming down, just gravity. The biggest factor IMO is what you are hauling. If it is construction trash I know from experience you can dump 4 loads without needing a battery recharge, as my pickup didnt have the charge line at the time. Something heavier like dirt or gravel might use a little more juice.
Old Mar 15, 2008 | 04:03 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
If you park near 110V. you could attach a boat battery charger to it. We did this with our buses at our school district to keep the amps up in extremely cold weather.
Old Mar 15, 2008 | 06:47 PM
elmo8641's Avatar
elmo8641
if you are using the trailer every day the solor charger will not keep the battery charged. they are very low amps. they are just to maintain a battery when it is not in use. what ever you do make sure the charger is automatic so you don't overcharge the battery. i would buy a charger that you can plug in.
Old Mar 15, 2008 | 09:02 PM
Beast12's Avatar
Beast12
The trailer will not be used everyday. Even if it went out everyday it would mostly be to move the skid steer around. I can see it going out a max of 2 or 3 times per week.
-Matt
Old Mar 16, 2008 | 12:33 AM
mudmaker's Avatar
mudmaker
I think the solor charger would be fine in your situation. I just looked in catalog I have and they have a 5watt as well as 15 watt trickle chargers available. Considering it is only being used as a dump occasionally the battery should have plenty of time to recharge. You would just have to realize you arent going to be able to use it more than 5 or 6 times in a short amount of time.
Old Mar 16, 2008 | 12:49 AM
jake00's Avatar
jake00
thats a sweet trailer
Old Mar 16, 2008 | 08:46 AM
elmo8641's Avatar
elmo8641
big differance between WATTS and AMPS. 15 watts will only be about 1 amp. it would take a long time to charge a 750 amp battery 1 amp an hour. watts equals amps x volts (W=A x V) to charge a battery you have to be at 14-15 volts. 15w=A x 14.5V amps would be 1.03amps. if you need to charge it from complete drain then it would take 650 hours of daylight. 12 hours of daylight would be 54 days.
Old Mar 16, 2008 | 09:31 AM
bigredtruckmi
Veteran: Navy
You are correct. It would maintain but not really do much for increasing amps over a short period of time (few days)
Old Mar 16, 2008 | 09:32 AM
grafekie's Avatar
grafekie
Solar charges don't have near the output you'll need to run a dump trailer. Wire the trucks You won't regret it. Anything else will be constant effort and worry. Do the trucks once and forget about it.
Old Mar 16, 2008 | 12:46 PM
Beast12's Avatar
Beast12
Ya, well my Dad went and bought ANOTHER trailer yesterday. We are getting into lawn care and maintenance. The new landscape trailer has brakes on it. So, I will probably be adding trailer brake controllers to a few trucks. I might as well wire in the charge wire. I am going to have it open anyways.
Anyone have any diagrams for trailer brakes as well as a battery charge wire?
-Matt
Old Mar 16, 2008 | 01:11 PM
bigredtruckmi
Veteran: Navy
Are the trucks wired and you just need controller hookup or complete wire job? What vehicles are we looking at?
Old Mar 16, 2008 | 01:24 PM
Beast12's Avatar
Beast12
Well, my Dad's 99 F-150 and my 01 F-150 are good to go. But I have a 1995 F-250, a 1988 Super Duty and a 1991 F-350 that I have wired a 7 way plug up on. BUT, only the trailer lights (brake, turn, running lights) are hooked up. So I guess I would need to do everything else.
-Matt
Old Mar 16, 2008 | 01:43 PM
stormyrider's Avatar
stormyrider
If your truck already has the towing package, the aux wire is already run to the trailer connector on the pickup from the factory. You would just require the break control unit up front, ties in under the dash with the adaptor harness for your truck, and wire the trailer side to the trailer connector.
Old Jun 21, 2008 | 07:39 PM
Beast12's Avatar
Beast12
Well, I hardwired the 91 F350 up and did my truck as well. I guess the question I have is the power wire comes directly off the battery. How should this be hooked up? Use a relay? What size of fuse or breaker should I use? Also, what size fuse should be used for the brake controller power?
-Matt
