Sponsored by: Real Truck
Bump Stops
Old Sep 4, 2017 | 12:24 PM
the cleaner's Avatar
the cleaner
Bump Stops
My Bump Stops have completely dry rotted and fell off the truck. I have an 08 with a 2 inch leveling kit, I already did all the body bushings, as they disintegrated as well. Should I bother replacing them? I highly doubt that I would ever bottom out that bad that I would need them?
If I should replace them, then where did u guy's get them and should I go with the Neoprene like I did with the body bushings?
https://goo.gl/photos/4RWG42uW2PifYivDA
Old Sep 4, 2017 | 12:31 PM
cyncwby's Avatar
cyncwby
I don't think I've ever been on the bump stops on any of my trucks, decision is up to you but if you replace them I'd go with the stock ones.
Old Sep 4, 2017 | 12:41 PM
Leon82's Avatar
Leon82
When I make a dirt or gravel run I'm on the bump stops
Old Sep 4, 2017 | 12:50 PM
seville009's Avatar
seville009
i had bump stops for the leaf springs rot out; thise were easy to replace. Are you talking about those, or the axle bump stops?
Old Sep 4, 2017 | 12:51 PM
Rob89's Avatar
Rob89
Replace them with Timbrens...
Old Sep 4, 2017 | 12:52 PM
Ron94150's Avatar
Ron94150
If your going to bother to replace them, I would use timbrens, at least they will be functional.
Ron94150's Avatar
Ron94150
Dang, you beat me by 33 seconds
Old Sep 4, 2017 | 01:19 PM
the cleaner
Yes the Axle Bumps
Old Sep 4, 2017 | 06:06 PM
CPaulsen's Avatar
CPaulsen
Took mine off and they are in great condition but put Timbrens on for towing my 5t wheel.
Old Sep 4, 2017 | 08:34 PM
the cleaner
Must be the FL Heat, mine actually crumbled. Found large pieces on my driveway, picked it up and it was like picking up crumcake...lol
Black Ford XLT
1978 - 1996 Big Bronco
Jan 16, 2017 11:38 PM
Jmiller68
Jan 2, 2017 03:10 PM
mudder460
Arkansas Chapter
Aug 16, 2009 05:48 AM
buckeyebronco
Jul 30, 2003 07:18 PM
89Bronco_EddieBauer
May 20, 2003 10:43 PM
