Can't unplug dimmer switch
Old Sep 3, 2017 | 10:24 AM
82_F100_300Six's Avatar
82_F100_300Six
I searched and could have bumped a twelve year old thread.....
I've been driving through a lot of water because of Harvey.....now I've got a headlight on\off foot switch
So I'm taking it out to dry and clean.....can't get the thing unplugged probably seized with rust. Should it pull straight off?
Old Sep 3, 2017 | 11:49 AM
Cg willie Willie's Avatar
Cg willie Willie
Yes that should just pull straight off you should maybe disconnect the battery and if you have too use a small screwdriver to pry it off you can get a new one at most auto parts stores
Old Sep 3, 2017 | 01:46 PM
CountryBumkin's Avatar
CountryBumkin
Spray some penetrating oil into the connectors. Let it soak overnight.
Old Sep 3, 2017 | 06:53 PM
Franklin2's Avatar
Franklin2
Autozone sells a new dimmer switch and a new plug with short wire pigtails. You could make note of the wire colors and their positions, and then snip the wires and replace the whole thing. See if they have some of those butt connectors with the shrink tube made on the ends.
Old Sep 3, 2017 | 06:59 PM
82_F100_300Six
Thanks everybody. I decided not to force it so it all got drenched in pb blaster and put back together. Fun stuff doing seventy mph and switching your headlights off with your dimmer switch.
Connecticut Calvin
Jan 8, 2016 06:40 PM
Bwetzel
Nov 20, 2012 12:40 PM
klemklubfoot
Oct 6, 2010 11:53 PM
GregTruck
Dec 29, 2004 11:59 PM
Mary_Kate_Olsen
1978 - 1996 Big Bronco
Aug 7, 2003 03:34 PM
