Headlight switch contact cleaning?
Old Jan 4, 2016 | 08:41 AM
Connecticut Calvin's Avatar
Connecticut Calvin
Hi all - I'm getting my 12 volts out of my headlight wire when the switch is pulled all of the way out but I lose power when I connect the headlights and the switch is under load. I'm guessing the contacts need cleaning after the truck sat in a field for 15 years. Is it possible to clean it up?
Thanks in advance.
Old Jan 4, 2016 | 11:34 AM
Scotty's 52 F3's Avatar
Scotty's 52 F3
This worked on my turn signal switch so I tried it on my headlight switch. The headlight switch went from crusty and green to looking new.
I did not take the headlight switch apart. Just soaked it in a plastic bowl. Used a brass detail brush on the heavy stuff and rinsed it really well. Looks and works great.
Old Jan 4, 2016 | 11:42 AM
Connecticut Calvin
Thanks! I'll give it a go. I'll report back with the results.
Old Jan 4, 2016 | 08:30 PM
49fordv8f4's Avatar
49fordv8f4
You can Carefully bend back the tabs that hold the switch together and take them apart. I said carefully as sometimes the tabs will break. Watch when you open it that pieces don't go flying, there are springs under the sliding contacts to keep them in good contact. When you get it apart you can clean out the old grease and sand all of the contact surfaces with fine sandpaper, I think I used 320 or 400 grit. Smear some dielectric grease on the contacts and moving parts inside and put it back together, bending the tabs back down tightly. I did this to the light switch and dimmer switch on my '47 COE and they always worked good after that on 12V. The grease had dried in the dimmer switch and it wouldn't change but, worked fine after I cleaned it.
Old Jan 4, 2016 | 09:51 PM
Scotty's 52 F3
I forgot to mention I squirted dry silicone inside and blew it out with compressed air. I didn't take it apart like Mark did so no grease inside. So far so good though.
Old Jan 5, 2016 | 12:15 PM
arctic y block's Avatar
arctic y block
Do Not bend the tabs straight up all the way
as they are more prone to break. I bend them
just far enough to get it apart. even then some
will break. But there are ways to make it work
fine even if they all break off.
Old Jan 5, 2016 | 09:19 PM
Nicholas+'s Avatar
Nicholas+
Did you try just spraying some electric contact cleaner or de-ox-it in the switch?
Old Jan 6, 2016 | 05:06 AM
Connecticut Calvin
I haven't tried spraying it no. That thought crossed my mind. But I felt it might only be temporary. The dimming mechanism inside is squeaky and doesn't always make contact and now with the headlights not working it just seems the old switch needs a tune up. I'll take it apart and do it right the first time so it doesn't come back to haunt me during some late night drive home.
Old Jan 6, 2016 | 08:58 AM
1950FordF1's Avatar
1950FordF1
CC:
Sounds like you are on the right track.
I choose to disassemble the switch from my F1. I did not want problems later on.......After seeing the condition of the dried grease and dirt accumulation I was glad I took the time to do it. I don't think I could have cleaned it out without opening the case. It was easy and did not take long to do so
Old Jan 6, 2016 | 09:30 AM
abe's Avatar
abe
Why don't you just buy a new one. If your rheostat (the dimming mechanism) is squeeky, who knows how long it will last. The rheostat is a coil of wirebthat will break after a long while.
Old Jan 6, 2016 | 12:15 PM
Connecticut Calvin
I really enjoy keeping as many original items on the truck as possible. I'm sure many people feel the same way about their own. If it's shot then yes I absolutely will get a new one.
Old Jan 6, 2016 | 01:41 PM
abe's Avatar
abe
Oh, I hear you. I am the same way. When I redid my truck instead of buying new ***** for the dash I just painted them gloss black and they look great to this day 17 years later. My rheostat didn't work so I bought a new light switch.
Old Jan 6, 2016 | 02:01 PM
Connecticut Calvin
On, I hear you. I am the same way. When I redid my truck instead of buying new ***** for the dash I just painted them gloss black and they look great to this day 17 years later. My rheostat didn't work so I bought a new light switch.
Where's the "like" button here?
Old Jan 8, 2016 | 04:26 PM
petemcl's Avatar
petemcl
Hi Calvin,
You might want to check elsewhere in your system first, particularly the ground cables and both battery connections. Also check the wiring to the headlights. You didn't say but I'm assuming that this is your '56 F-500?
And if you find nothing I agree with abe . . . just replace the switch. They are not that expensive. Just be careful to check everything thoroughly first or you might fry the new switch.
Old Jan 8, 2016 | 06:40 PM
Connecticut Calvin
Originally Posted by petemcl
Hi Calvin,
This is my F-500 yes. All grounds were checked prior to installing the brake lights. They're solid. I'll take the switch out tomorrow and have a look. I'll take a few pictures along the way. Like I said earlier if it's shot or shows obvious signs of wear I don't want to take my chances and I'll buy a new one.
Eddillard79
Jul 26, 2015 02:41 PM
Bwetzel
Nov 20, 2012 12:40 PM
aleutianman
Electrical Systems/Wiring
Oct 16, 2008 01:01 PM
knash0727
Sep 13, 2008 06:04 PM
