how to test timing chain?
Old Sep 8, 2003 | 03:23 PM
dapozer's Avatar
dapozer
how do I test this thinng and check it for wear? it seams to have some play in it and need to know when to change it or if it needs it. do chains really stretch? the gears look in good shape.
thanks
shawn
Old Sep 8, 2003 | 04:25 PM
BB's Avatar
BB
Remove the distributor cap, put a big socket and breaker bar on the crank pulley and rotate the crank back and forth. Watch for when the rotor just begins to turn. The crank will turn easy when it's in this slop zone. See how many crank degrees of slop there are, 10* is time to change, 16* is time to jump a tooth.
Barry
Old Sep 8, 2003 | 06:16 PM
Comegetsome's Avatar
Comegetsome
16* is time to replace some valves.
LV Dan
Jan 7, 2018 05:50 PM
Dizzy28
Projects
May 1, 2017 09:47 PM
frummy
6.7L Power Stroke Diesel
Apr 19, 2017 09:13 PM
sgrol
16
Oct 29, 2015 09:16 AM
pensacolaexplorer
Oct 26, 2007 10:01 PM
