P0107 & P0108
Old Aug 31, 2017 | 08:56 PM
b-grant's Avatar
b-grant
P0107 & P0108
Had check engine light come on tonight. Codes p0107 & p0108. Anyone had this happen? Turbo gauge is maxed out but feels like no turbo at all. Dealer probably can't fix until next week and I need it the truck for the weekend. If it's likely just a sensor and I can get one locally I'll change it myself. Any issues if I keep driving it as is? 2017 6.7 14,000 miles. Thanks in advance.
Old Sep 1, 2017 | 05:18 PM
b-grant's Avatar
b-grant
No one has any info?
Old Sep 1, 2017 | 05:27 PM
stewy604's Avatar
stewy604
These are both MAP sensor codes, 107 is low voltage...108 is high voltage. Check your MAP sensor connection, could be a failed sensor otherwise. Other possible causes would be a vacuum leak, or a short. A good way to diagnose if the MAP sensor is to blame would be to compare the MAP sensor reading (key on engine off) on a scan tool with the barometric pressure reading. They should be the same because they both measure atmospheric pressure. The higher the engine vacuum, the lower the voltage reading. From what i can see online, the voltage should range between about 1 volt (at idle) to about 5 volts (WOT).
Old Sep 1, 2017 | 05:45 PM
b-grant's Avatar
b-grant
Thanks. Any idea where that sensor is located on this engine? Is it going to damage anything if I continue to drive it over the weekend?
Ron Purpura
2004 - 2008 F150
Mar 12, 2013 07:50 AM
pjnadon
Jan 22, 2011 10:01 PM
76250_4x4
Aug 12, 2010 10:09 PM
Flatlanded87
Aug 25, 2006 07:03 PM
dant
Apr 1, 2004 07:28 AM
