towing question
Old Aug 31, 2017 | 07:24 PM
chiefn10's Avatar
chiefn10
towing question
towing a 12 ft trailer this weekend w/ about a thousand pounds of weight on it. do i set tow mode on my tuner or on the gear selector. cant remember which one over-rides the other. thanks
Old Aug 31, 2017 | 08:17 PM
036.0stroke's Avatar
036.0stroke
If you are serious then the answer is no you don't need to do either. That is not enough weight for the truck to even notice
Old Sep 1, 2017 | 12:42 AM
r2millers's Avatar
r2millers
I think I'd use the column button first. One way or another, once it's in tow-haul, you'll feeling the difference in shifting points and downhill shifting if engaged.
To 036's point, it's not much weight to be overly concerned.
Old Sep 1, 2017 | 10:01 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
What tuner and tune? If you're running something like Innovative's Extreme Race that locks the TC through most/all the gears, I wouldn't tow anything, even minimal weight. I also wouldn't DD a race tune like that in the first place.
Tuner overrides the T/H switch's program, all the switch does is move to whatever shift program the tuner pushed in. Which for most seems to mimic stock, unless you got an aggressive T/H tune with an intentionally different T/H shift schedule.
Old Sep 1, 2017 | 12:43 PM
036.0stroke
As long as tuning is not crazy and you drive with a little common sense these trucks Very capable tow vehicles. I tow close to 30k gcvw with mine with a street tune and don't have to use the tow button unless I want to. You will be okay
Old Sep 1, 2017 | 02:02 PM
BryanStein's Avatar
BryanStein
I'd rent a nice cab-over Kenworth for that kind of tow. Do you have a CDL?
If you're serious, the truck will not notice a 1000 lb trailer is back there. It doesn't matter which you select. Perhaps the question needs to be rephrased?
hav24wheel
64
Sep 5, 2016 08:56 PM
sflem849
15
Aug 15, 2011 03:05 PM
jrobpwrstroke
6.4L Power Stroke Diesel
17
Jul 27, 2011 09:57 AM
rustydailey
Oct 7, 2007 12:52 PM
98Cobra
2004 - 2008 F150
Sep 7, 2004 09:20 AM
