Gosh, I love these debates as it keeps the forum lively and everyone gets to try different methods with your truck.
Troverman, You are right in what you say for 98% of the situations but there's always those 2% of the times.
I have a diesel and I could certainly get my truck back onto the pavement by flooring it but that is hard on the tranny torque converter. I just had to barely hit the gas when in 2 low and it would pop right up.
As far as the locker goes, I agree they are hard to control in the snow and I try not to use them but like you said when the deep snow just sucked you in the ditch and one front tire is not hiting solid ground, the locker saves you a winching job or tug strap pull from your wife (embarrassing!) i have kind of mastered a technique taking a good run up the steep drive in deep snow with all 4 locked in my Dodge and letting down on the pedal just enough to make the turn.
I have taken your advice and I'm waiting on installing a front locker on my SD until I see how well this torque management (or whatever it's called) works applying power to the correct front wheel via braking. At least that's what I remember you telling me. I will report back after winter!!
had 99.5 7.3L 6 speed manual for 13 years before it was T-boned. put in 4 low at ramp in 1st and pulled boats out at idle in 2 low, left front hubs unlocked as ESOF front hubs cost me tons of money....went manual with Warn. i do not think my technique is going to kill the case or rear. 4lo, front hubs unlocked (1 less step at ramp) works great!
well I'll be a...got in truck after work. started truck and shifted imto 4H no problem....smooth. Put in neutral, foot on brake, from 4H to neutral smooth, then into 4Lo presto! Guess it was first time jitters (break in)! All is good....let me at that boat ramp
Actually the current transfer case low is 2.64:1 and the NVG 271/273 cases with the (lower) low range continued to be used through 2016.
So I looked up 2012 transfer cases and you're right its still the np271 design but no branded. Makes you wonder if they produced a surplus for Ford before going bankrupt? I do know Ram switched to Magna right after 2012.
Correct me if I'm wrong but the manual 4x4 system requires locking the hubs manually for operation since there is no vacuum locking the hubs for you. I pretty sure the manual states DO NOT shift into 4x4 without having the hubs locked as it may cause damage. I have the manual 4x4 system and have no problems using it at all, as long as I get out and lock the hubs in.
+1 Thenewboss is correct! Always lock the hubs, I prefer the old manual system as I have never had a problem with it. I've had 2 trucks with the "fancy" push button system and have had expensive (after warranty) problems with them, I guess I just keep my trucks to long.
