In a previous thread I posted that I had the opportunity to work on a 88 Bronco II 2WD 5-spd. For some background, the truck hasn't been registered since 2008 and probably hasn't ran in at least that time.
I go it to crank but I don't hear fuel going to the injectors (no hissing sound) but the relay/switch works. I know this Bronco had a low pressure pump in-tank and a high pres. in-line. Should I replace both? Replace the in-tank pump with a high pres. pump? If I do that can I leave the old high pres. Inline pump and just unplug it to avoid adding more fuel line? Any other help would be appreciated. (It doesn't start with gas in the intake either so the injectors are likely clogged)
