1978 - 1996 Big Bronco
91 silver fuel pump on
Old Oct 1, 2003 | 05:17 PM
so b it's Avatar
so b it
i have a 91 silver with a 302. when you turn the key to the on postion you can here the fuel pump prime but it does not stop. checked the pressure relief on the fuel rail and i have gas there. truck will turn over but will not crank. thank you for any help.
Old Oct 1, 2003 | 10:13 PM
dblue351's Avatar
dblue351
I think you mean iot will not fire? The pump might not be pumping enough pressure to the injectors. They take 19 PSI to open, most pumps are around 40-50. Mine just died yesterday so i get to replace it! I cant wait.
Old Oct 2, 2003 | 05:53 PM
so b it's Avatar
so b it
so if the injectors do not open the pump continues to run? Dblue351 let me know what all it takes to change the fuel pump. thanks for your knowledge.
