1978 - 1996 Big Bronco
351 Throttle Body Sensor
Old Aug 30, 2017 | 12:37 PM
pappy19's Avatar
pappy19
So how bad is it to replace a TBS? YouTube shows you have to take the throttle body totally off. Any advice would be appreciated.
Old Aug 30, 2017 | 01:42 PM
Kemicalburns's Avatar
Kemicalburns
yes you need to pull the throttle body to change that sensor. make sure you have a new throttle body gasket on hand. Use Throttle body cleaner only on the TB.
why do you think the tbs needs replaced?
Old Aug 30, 2017 | 02:11 PM
pappy19's Avatar
pappy19
Running ragged, shifting weird and finally the check engine light came on. Analysis said it was TBS.
Old Aug 30, 2017 | 05:32 PM
Conanski's Avatar
Conanski
I guess you mean the Throttle Position Sensor(TPS)? If so yes.. it's near impossible to get at without removing the throttle body from the intake.
Old Aug 31, 2017 | 12:34 PM
Kemicalburns
if you can buy motorcraft do it. I have had several aftermarket versions not perform well.
mayerst
Jan 9, 2022 07:10 PM
doctisdall
Jan 9, 2022 06:08 PM
adam.hilberath
Jan 13, 2013 03:37 PM
