Decode engine Casting numbers?
Old Aug 29, 2017 | 03:11 PM
lvin4jc's Avatar
lvin4jc
Ok, I assumed that there would be an easy online doo-hicky that did this easily but if there is I sure can't find it.
I am hoping that I bought a really clean old 300 I-6 but i'm wanting to make sure.
Engine casting number on the block is:
D7BE
6015-CA
As near as I can tell D7 means 1977, I have no idea what B means (someone said Bronco???) and E means engine.
Whether any of that is correct, all i'd really like ot confirm is that it is indeed a 300.
Help please!
Old Aug 29, 2017 | 03:32 PM
lvin4jc's Avatar
lvin4jc
Old Aug 29, 2017 | 03:43 PM
The Frenchtown Flyer's Avatar
OOooooo - bummer. That is a small six, not a 240 / 300. Probably a 200, in the 144 / 170 / 200 / 250 family.
Old Aug 29, 2017 | 03:47 PM
The easiest way to tell a 240 / 300 from the smaller sixes is the smaller sixes have an integral intake manifold (cast into the head) and the 240 / 300s have a bolt-on intake. Many other external clues, like the placement of the oil filter and distributor, also exist.
Old Aug 29, 2017 | 04:22 PM
lvin4jc's Avatar
lvin4jc
Yeah, it's not looking good huh? Any way to tell the 200 from the 250? The intake is integrated into the head for sure, 4 bolt water pump.
To clarify, do all 300's have the big panel on the driver's side that holds in the oil? My 240 does and I keep hearing they're the same engine, different stroke?!?
Old Aug 30, 2017 | 08:55 AM
Yes, all 240/300s have the lifter cover "panel" on the driver side.
Old Aug 30, 2017 | 04:00 PM
KULTULZ's Avatar
KULTULZ
Post
The 250 was not introduced until 1968.
Old Aug 30, 2017 | 06:42 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I am hoping that I bought a really clean old 300 I-6 but I'm wanting to make sure.
Engine casting number on the block is: D7BE-6015-CA
Whether any of that is correct, all i'd really like to confirm is that it is indeed a 300 (it's not).
Casting numbers are foundry marks, cannot be cross referenced to Ford part numbers.
Bronco was not available with the 300 I-6 until 1980, and this is not a 300.
Intake manifold cast as part of the cylinder head, it's either a 200 or 250 I-6 from a 1977 Ford or Merc 'mid-sized' Passenger Car.
Old Sep 6, 2017 | 12:39 AM
fordman75's Avatar
fordman75
What's the #'s/letters to the right of the casting # under the Ford oval? The casting #'s will give you a general idea on the vehicle and age. The #'s/letters under the Ford oval are the date code. That will tell you the day, month and year the block was cast.
You've got a 1977 or newer 250 small 6.
The 144, 170 and 200's only had 3 water pump bolts. The 250's had 4 water pump mounting bolts.
I can't find what the "B" stands for in the casting #. It's not a Bronco since the only 6 cylinders available in the 77 & older Bronco's were the 170 & 200. 78 &79 Bronco's were only available with the 351M & 400 V8's. Like what was already mentioned the 300 wasn't available in the Bronco until 1980.
Being a 250 I'm guessing it probably came out of a Granada. The Maverick was also available with the 250 but I believe it would be a "D" instead of the "B".
Old Sep 6, 2017 | 04:53 AM
KULTULZ's Avatar
KULTULZ
Post
B = Bronco (1970-1973)
B = Maverick (1975-1977)
B = Fairmont (1978-1983)
SOURCE- Ford Part Numbers, Casting Numbers, and Date Codes
Old Sep 6, 2017 | 01:17 PM
fordman75's Avatar
fordman75
Thanks for the info!
Then it most likely came out of a Maverick. Or possibly a Fairmont ( I thought the only 6 available in them was a 200 ) .
Old Sep 6, 2017 | 02:04 PM
NumberDummy
Originally Posted by fordman75
Then it most likely came out of a Maverick. Or possibly a Fairmont.
No Fairmont or Zephyr came w/a 250.
250: 1969/73 Mustang; 1969/74 Fairlane/Torino; 1970/77 Maverick/Comet; 1975/80 Granada.
The list in post #10 is next to WORTHLESS .. has a gazillion errors and omissions!
KULTULZ didn't know this, but I do, because I knew the two IDIOTS that originally "made it up."
The two IDIOTS published the "Red Book" that was sold in book stores in the 1970's. Others have taken and used the info ever since.
The IDIOTS were members of the Fabulous 50's Ford Club, and "made it up' is exactly what they did.
They had no Ford literature of any kind, based some of it on Warranty Plate codes, vehicles they "looked at" at car shows. The rest of it, they just "guessed."
For example: How many Maverick's have a B as the 3rd digit in the part number prefix? N-O-N-E = NONE!
Maverick used a D as did Falcon and Granada.
Old Sep 6, 2017 | 02:57 PM
fordman75's Avatar
fordman75
Come on Bill. If you are going to quote me to say I'm wrong. Don't delete the part of the quote I wrote about I thought the only 6 in the Fairmonts was the 200.
Due to the casting # it can't be older then 77. So that rules out the Mustang, Fairlane and Torino. And since we all now know no Fairmont came with a 250. That would leave the 77 Maverick/Comet or the 77-80 Granada, Correct?
Do you happen to know what the "B" in the casting # does refer to?
Thank you for sharing your knowledge. And for correcting me when I'm wrong ( happens way too often ) .
Old Sep 6, 2017 | 06:12 PM
KULTULZ's Avatar
KULTULZ
Question
Uh Bill...
The B in the third prefix position (Engineering No - Not Service Part No) denotes the car line the part was initially released for. I spent a few years in parts rooms also and fully understand how the P&A System works. That character may or may not appear in a SERVICE PART NUMBER PREFIX. Example, the MUST Catalog Character is F while the actual Service PN Prefix Character is Z, while the Engineering Casting I.D. No. was usually D (all depending on time frame).
I am well aware that most info out there is on a curve. But just take a moment to re-think the subject. That particular info is correct. The B applies to BRONCO (70/73), and the car lines mentioned (MAVERICK 75/77 and FAIRMONT 78/83). The date code(s) are what identifies/separates them.
As a side note, I was re-writing and correcting all of the info on the net to try and make it more concise (to my limited knowledge). I had a crash and it took care of my notes. I may try it again.
Old Sep 6, 2017 | 07:59 PM
KULTULZ's Avatar
KULTULZ
Thumbs up
That is the only visual clue. The 250 is a little taller and fatter.
Did you find the date code?
EDIT-
Below is an Engine I.D. Chart used by re-builders (and I am sure it is incomplete and/or in-concise in many entries). It includes all makes but I have cropped just the FORD 250 info. While most third position characters are D (which is concise as you entered), B is also used in some 250CI casting numbers.
