Cooling Issue
Old Aug 27, 2017 | 12:09 PM
Hanger53's Avatar
Hanger53
Cooling Issue
Been fighting a heating issue with my Flathead since I got the truck. Runs normal as long as I stay below about 2400. (or ambient temps below 70 deg) If I push it above that it starts to warm up considerably. Don't know if it will go full hot as I have not continued to push it. As soon as I slow down it will slowly cool off.
Radiator was cleaned recently, new water pumps, new belts, 160 thermostats, running straight water at this point (doesn't seem to change with antifreeze in it)
Have not pressure checked the system but don't appear to be losing water any where. Also, running gauges on both sides at this point and they seem to run close to the same temp...
I could just drive around at 47 mph or change the rear end ratio I guess but I would rather find the issue, if there is one..
Is continued operation above 2500 rpm more than I should expect???
Old Aug 27, 2017 | 02:08 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I've run my flattie at 2300 - 2500 in 100 deg weather for entire days, runs the same as in the winter, except on really long, steep hills, then it will go up a needle's width and drop back after the hill. I have a 4-row brass radiator, a shroud, but only a 3-blade fan (car-style).
My first guess would be your WP belt isn't tight enough, and is slipping at higher RPM. Have you lubed the fan lately?
The engine itself could be full of mud. Have you ever had it open? It would be worth pulling a thermostat to see what the water jacket looks like. What does the water look like?
Old Aug 27, 2017 | 09:36 PM
Flat Ernie's Avatar
Flat Ernie
I agree with Ross on the initial diagnosis...if those things all check out good, perhaps a partially blocked radiator could be to blame. Check timing too - if you're not getting any advance
Old Aug 28, 2017 | 07:50 AM
Hanger53's Avatar
Hanger53
Thanks for the input guys.
When I got the truck, it had been sitting for a few years in a barn. I drained and refilled all the fluids, including the coolant before I got it running. I noticed the cooling issue right away but as the outside temps dropped last fall it became a none issue. Before i drove it last spring I pulled the radiator and had it boiled and cleaned, removed old water pumps and thermostats and used a hose to flush the block from top to bottom, installed new water pumps and thermostats (160s) and new belts filled with a 50/50 mix. Took it for a drive and had exactly the same issue, no change at all. I installed two gauges, one for each side and both sides warm up and run very near the same.
The timing was my next guess too but I'm having trouble finding a timing mark on my pulley. Might get a chance to diagnose more today...
Old Aug 28, 2017 | 09:55 AM
ALBUQ F-1's Avatar
ALBUQ F-1
You can at least tell if there is vacuum advance happening with a timing light. Put in a few degrees more advance, see if it helps. As long as you don't get pinging it won't hurt.
Old Aug 28, 2017 | 12:39 PM
hooler1's Avatar
hooler1
I have chased the same thing. It sounds like a coolant flow issue to me. Just enough flow at low speeds but once you get into a higher RPM not quite enough coolant flowing through the radiator to maintain or regulate the engine temp. I would check what everyone else has mentioned such as for sludge in the water jacket and making sure your vac advance timing is working and correctly advancing. I know you mentioned having your radiator boiled and cleaned but sometimes it just doesn't get all the crud out. If all else fails maybe looking at rodding it out or (gulp) replacing it.
Old Aug 28, 2017 | 12:59 PM
ALBUQ F-1's Avatar
ALBUQ F-1
What temperatures are you seeing on each bank? at what outside air temperature? I would expect temps somewhere near 185-190 in the summer. That is perfectly fine.
Old Aug 28, 2017 | 02:02 PM
rswhitmore's Avatar
rswhitmore
I would first suspect retarded ignition timing. If you rule that out I would look at water flow, possibly too much. I remember reading about people having to install washers or restrictors in the radiator hoses because the flathead water pumps move the water through the radiator too quickly at higher engine speeds to allow enough time in the radiator for the water to cool down. Anyone else recall this?
Old Aug 28, 2017 | 04:09 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Originally Posted by rswhitmore
... I remember reading about people having to install washers or restrictors in the radiator hoses because the flathead water pumps move the water through the radiator too quickly at higher engine speeds to allow enough time in the radiator for the water to cool down. Anyone else recall this?
That's an old wives' tale. If the water moved thru the radiator too fast to give up its heat, it would move thru the engine too fast to pick up heat. People did used to run washers instead of thermostats on some older flatheads, for different reasons.
It is possible that OP simply has two bad thermostats. I had one that wouldn't open fully. On a trip in hot weather, climbing a lot of hills, the gauge would go up noticeably, then cool down on the back side of the hill. When I got home, I put it in a pan of boiling water with a new one. The old one would open about 75%, and stop. The chances of getting two bad ones may be slim, but.... it happens. They are cheaply made.
People on the Ford Barn have made a study of thermostats, some are rated for higher flows. These are the ones they recommend:
NAPA THM 530060 (160 deg)
Robertshaw #330-160
The Robertshaw is a high-flow model.
Old Aug 28, 2017 | 04:39 PM
CharlieLed's Avatar
CharlieLed
I am running Evans Waterless coolant in my 56 and my 40...375 degree boiling point and almost no thermal expansion.
Old Aug 30, 2017 | 11:37 AM
petemcl's Avatar
petemcl
I guess my first question is what do you mean by "warms up considerable"? Do the gauges go all the way to hot? How much coolant loss do you have out the overflow when this happens?
Old Aug 30, 2017 | 01:42 PM
ben73058's Avatar
ben73058
Hey Hanger,
First.... It's good to have a running truck! You are 90% there. You talk about it
acting up when it's above a certain RPM... Could the problem be happening at
highway speed? We went round & round looking for an over heating issue on our '50.
We were missing a lot of the stock airflow pieces up at the front of the
truck. There are pieces that belong next to the radiator, under it, & over it to
force the air back through the radiator at speed. If you don't have these pieces your
truck won't cool properly.
Good luck over there. (We eventually just went for the biggest electric fan we could find
in the local salvage yard plus we addressed our air flow around the radiator....problem solved.).
Ben in Austin
1950 F1 (351W/AOD)
Pushachevy
Jul 27, 2016 09:24 AM
tbm3fan
Oct 28, 2014 12:40 PM
dutchlincoln79
16
Jul 11, 2010 10:58 PM
lbrauer
32
Jun 7, 2010 12:22 AM
KR1
13
Jun 25, 2009 01:59 PM
